Knocking from somewhere.
jhatley7
2016 White GT PP, 2022 F350
[MENTION=9610]jayman33[/MENTION] is build my sleeved short block.
Sry about you luck.
jayman33
Fort Bragg, NC
Jason
24 GT
Manley H Beams and off the shelf pistons typically won't handle 1500hp. Is the block sleeved?
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
Thank you all for the input.
so I opened my oil filter and found this :(
Now that I found the issue. I will be looking at my options for built long blocks. :cheers:
If you have any suggestions on long blocks let me know!
Thank you!
Wow ... I really feel bad for you .. I love to tear that motor down and find out what the cause was ...:brokenheart:
Crackerjack17
WV/Maryland
2017 GT PP
Ouch. Well, a lot of us were wrong. That thing must be pretty worn somewhere the way it was rattling around. Good luck with the rebuild.
sigintel
Ray
2018 GT
Can you post back some pics if the motors available for teardown to see wtfhappened?
Only learn so much from assembly, real knowledge seems to come from teardown.
ven377
ven377
San Diego
2015 GT
Im going for 700-850 wheel at the most.
Not Sleeved.
It was between this @$10,200 and the aluminator for @$9,700 500 bucks cheaper with alot less parts.
Do you have any better long blocks at that 10k price range?
ven377
ven377
San Diego
2015 GT
Ill get pictures in the process of the tear down :thumbsup:
esacteksab
CO & KS
2015 Mustang GT
What was the combo? How many miles on the Whipple? 91? 93? E-85?
If your heads are good, get an Aluminator shortblock if you're only looking for 750-800. For that matter, maybe you can find a local shop to put rods & pistons in your block if it'll clean up. If you're lucky crank only needs polished.
whatsup62
Jupiter
probably already covered but what tune and oil were you running?
