engine oil temp observation - 2016 tech pack car
CANTWN4LSN
northwest
2017 GT350
It's entirely possible that the decision to add the air to oil cooler to all gt350 was made late in the game (possibly after data collected from the track tours?) And all the other documentation hasn't caught up.
Would love to see this confirmed by Ford. Would be nice if Tech pack cars had the extra oil cooler supposed to be only on Track and R but nothing official? Don't want to spread rumors. Don't care about trans and diff coolers as not planning on track use but am a little concerned regarding oil even just for spirited non track driving.
cloud9
Sioux Falls, SD
2019 Mustang Bullitt
Is the exploded drawing in post #13 incorrect? I'm fine if it is, as I had hoped they did away with the sandwich plate cooler given the number of failures we had at the track with them. I'll drop the oil filter access door tonight when I get home and see what's up.
That drawing in post # 13 shows both types of oil coolers. If you follow the lower radiator hose 8286A in the drawing where it's modified with two small fittings coming out of the bottom, that's the one for a water-to-oil cooler. There are not fittings on hose 8286B which is the one used on the GT350. There are two types of aluminum fittings shown just left of the radiator fans. The sandwich plate used on the water-to-oil cooler is on the right, and the fitting that plumbs the two lines to the air-to-oil cooler in the driver side lower grille is on the left.
I put the car up on jack stands and opened the filter access panel to get a better look. You can see the aluminum fitting and oil lines in the photos below. This should clear up the confusion, and it also means they must have added air-to-oil coolers to all the GT350s.
Texas Gator
DFW area
2016 GT350 magnetic w/blk stripes, tech pack
Hopefully some other tech pack owners will also confirm if they have this cooler. I asked FP today when i called and they didn't seem to know one way or the other. If we wait long enough I can check mine :-)
Sent from my Nexus 5 using Tapatalk
cloud9
Sioux Falls, SD
You just need arsenalrocks to get under his car and take some pics :thumbsup:
Texas Gator
DFW area
Arsenalrocks took some pictures in another thread - they are blurry but may be the same fittings for the 2 hoses, and there is definitely a radiator behind the lower grill opening on the drivers side
cloud9
Sioux Falls, SD
It's an air to oil cooler, not water to oil.
Warmup is good because there is an oil thermostat that prevents flow through the cooler until the oil is warmed up. It's just like the 5.8L engines in the GT500s with the Track Pack remote cooler.
I would expect that we have a t-stat for the oil cooler, but even at that, it doesn't explain why the oil warms up so much faster than the Boss. The Boss has 8.5 quarts stock and the GT350 has 10 quarts (less than 1 quart in the cooler). Is it because the Voodoo creates that much more heat? I sure hope not because we battled cooling issues for quite a while with the Boss. I won't know until I can get on track this spring.
arsenalrocks
GTA
2016 GT350
[MENTION=17807]cloud9[/MENTION]: thanks for the pic, those two hoses look exactly the same as mine (tech pack)
and thanks for clarifying everything for us.
cloud9
Sioux Falls, SD
@cloud9: thanks for the pic, those two hoses look exactly the same as mine (tech pack)
You're welcome. Now if one of you Sun Belt owners would get on the track soon, you can ensure the cooler we do have is up to the task ;)
CoolTech
SoCal
www.cooltechllc.com
2006 Ford GT - Tungsten Garage Queen
Hmmm... not sure if it is the total explanation but the Boss' all had the sandwich water-oil cooler with cold water slowing the warm-up of the oil. Cloud9 - as you and I both know the oil & water temps of the Boss were VERY influenced by engine RPM - often necessitating a lap or more of short-shifting to bring temperatures down. With the astronomical redline of the GT350 motor, I am very concerned that we will see similar issues.
cloud9
Sioux Falls, SD
Yes sir.....have you looked into adding a supplemental cooler somewhere if we need it? Looks like you might be able to hang one off the bumper beam in the lower grille opening. I hope we don't have issues, but some magazine reports are already expressing concern about temps they were seeing on track. Part of me wonders how much we'll live at 8250 depending on how the gearing works at different tracks. The power band is wide, but in my limited street driving, it likes to be at 4k+ to make power.
