Engine note change/drone when in 6th gear
Gnatsum21
Fort Lauderdale FL
Former: GT 21 Roush Twister Orange RIP | ECO 2016
Manual trans: drone went away after retightening H-Pipe and sound hose/tube delete.
Magnetic Stang
Ohio
Chad
Again, there's no "basically" to this.
5th is 1:1 (not overdrive)
6th is 0.63 (quite an overdrive)
Ok, got me an a technicality... But in 5th gear at 40mph, it feels like an overdrive gear.
JDM_WAAAT
Denver, CO
Logan
22 Mach 1 HP 6MT EGM, 2016 Focus ST
No, it doesn't. moderate acceleration from 40 in 5th in no way feels like an overdrive.
Magnetic Stang
Ohio
Chad
lol. Ok. Let's forget I used the word "overdrive" to describe 5th gear. 5th gear around 40mph for me sits around or below 1600 rpm. A moderate acceleration would definitely feel like i was in the "wrong" gear.
JDM_WAAAT
Denver, CO
Logan
That's definitely how transmissions work!
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1, FJG, manual
But you best described the sound, it is like a low pitched diesel drum/hum that gets worse trying to unsuccessfully accelerate lol.
This is exactly how I would describe it, having been intimate with a variety of VW diesel engines in the past. Too low RPM and an attempt to accelerate basically stalled the engine and produced deep droning sound. The shape of the car's cabin adds to that.
WD Pro
United Kingdom
Lime GT
6th gear at 1500 rpm and only 200 miles on the clock ?
I understood that was a big no no for ‘running in’ ?
WD :like:
LikeMike
NYC
2022 Mach 1
WD :like:
If it is please explain to me why? I have read the manual but to be honest its vast and not very specific when it comes to details like this. Just says to vary the RPMs. Ive been driving like a madman and have bounced off the limiter more times than id like to admit.
WD Pro
United Kingdom
Lime GT
The UK manual has this statement on the end of that section "Do not labor the engine" which to me seemed to fit what you were doing to get that noise in the first place.
I know there's lots of opinions on running in (and lots of threads about it on here lol) but that piece of advice seems to be fairly consistent across most opinions.
This article seems to frequently get linked :
https://www.mullenixracingengines.com/how-to-break-in-your-engine
So on the other hand, the 'madman' bit seems to fit it quite well :giggle: :sunglasses: Just be wary of continued use of the limiter (rumoured to contribute to oil pump gear failure) :like:
WD :like:
RocketGuy3
2021 Mach 1 6MT, 2025 Cayman GT4 RS, 2025 RS3
There is no "seems like". 6th is a huge overdrive. You can use 6th gear at 40 mph if you want, so long as you use it correctly. It's not for acceleration unless you're going 60-65+, but even then you should probably downshift to 5th. Doing so sounds better anyway.
I couldn't accelerate from 40mph in 6th even if I wanted to lol. I downshift for 90% of my acceleration... It's more fun anyway. Just like shifting into 6th even if you don't really need to. We got manuals for a reason.
