Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2023 F150 Raptor
- Vehicle Showcase
- 2
Turning off the rear cats in the tune renders the state inspection (here in Mass anyway) impassible without returning the tune to one with the cats turned on. Then you have to drive the car long enough for 5 of the 7 systems to be “ready“. Good luck having that happen before the MIL activates again, which guarantees a failed inspection. This is why I always use the bungs and not turn off the rear cats via a tune. Have been passing Mass inspections for 15 years doing this.
EDITED TO ADD: I should have mentioned that I I was using an aftermarket tune on these cars. I am suggesting that you use the bungs instead of turning the cats off in the tune.
You can pass a state inspection with a tune. The rear 02 sensors have to be left on, therefore using the bungs with the tune. The only thing of concern (unless badly tuned emission wise -rich or lean-) that you are concerned about for passing is having no check engine light -MIL-.
I was also successful not tuning the car and only using the bungs.
