Educate me guys - Anti Roll Bars
MaskedRacerX
Driver
Vilano Beach, FL
DT
19 Mustang GT convertible, Orange Fury + Ebony, A10/PP/AE/MS/B&O
@S550VertCS
I also meant to say, that your starting point changes things quite a bit too.
My car is a Perf Package with Magneride. So right out of the box, it has upgraded springs/shocks/swaybar, different suspension tuning, Magneride is a whole range of improvements both in handling and comfort, PP convertibles also have extra bracing.
And all those components were designed to work together.
So I think I'd do the same thing with a suspension upgrade on a non-PP car, get a single sourced upgrade (BMR or Steeda), and since you're pulling suspension apart (and doing an alignment) for springs, do some matching shocks/struts at the same time, capitalize on labor effort and/or cost not being much more for both. Then of course, get a swaybar kit that's been designed to work with the other parts.
Advertisement
S550VertCS
PA
Scott
2013 V6 Mustang Convertible, 2020 GT Convertible CS
  • Thread starter
  • Thread Starter
  • #17
Guys, thank you all so much. Thus thread is a huge source of info for me and I am taking it all in and looking up a lot of stuff mentioned here and reading more on it. Thought I just wanted some springs, but I do want to do it right, and do if efficiently since I will bepaying others to do the work. But definitely want to tighten everything up.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
I just put a bmr rear sway-bar on , biggest difference is the firmness in the rear especially in turns. I set it to the softest setting. My front sway bar is still stock.. the rear factory bar is a twig with soft rubber bushings..
Danmg202
Oregon
2018 mustang gt- 401a - PP1
I did front and rear adjustable bars but ended up putting the rear bar back to stock. I really hated how the car felt with it on.
S550VertCS
PA
Scott
  • Thread starter
  • Thread Starter
  • #20
How did it feel?
Danmg202
Oregon
How did it feel?
A feeling of being very willing and ready to turn coupled with the rear having a lower threshold for stepping out. On the very bad pavement in the area it was upsetting the whole car I felt which amplified the first sensations. With it being around 50 percent stiffer than stock on soft it was just plain overtuned. Happy with the stiffer front bar anyhow, if I decide in the future I want more rear bar I'd pick a smaller increase to start with.
S550VertCS
PA
Scott
  • Thread starter
  • Thread Starter
  • #22
Thank you for the explanation.
Dominant1
Dr Frankenstang
Its totally different when your entire suspension is dialed In Correctly because i dont get that feeling..
S550VertCS
PA
Scott
  • Thread starter
  • Thread Starter
  • #25
This is what I would recommend for almost everyone.
Well I hope then it would only be to change the front and stay stock in the back. Cause if your advice to almost everyone is to change both, then go back to rear stock, well, I just ain't gonna do that. :) :) And because my emoticons never show up, that was totally said in jest. LOL
EDIT - So of COURSE they show up this time. /EDIT
[email protected]
Gold Sponsor
Illinois
2015 GT
Haha yes, just change front, stock rear. There are lots of good reasons for this.
Danmg202
Oregon
I'm not really sure how or why I'd want to dial it in to not correctly feel how the stiffer rear bar effects the car.
Dominant1
Dr Frankenstang
Adjustments need to be made to dial in how you want the car to drive. If you don’t do those kinds of things you should have a professional dial it in to have it do what you want it to do. A good place to start is a Performance alignment.
Here’s my performance alignment professionally done to my standards on how I’m going to use the car:
https://ibb.co/C1hZjhZ
[email protected]
Gold Sponsor
Illinois
2015 GT
That's a drag race only alignment. It's nowhere near enough rear camber to be safe for even spirited street use.
Dominant1
Dr Frankenstang
You can get a Performance alignment for road course track action street handling Fun etc.. Notice, i said i got it Done for what “I” want to use my car for not what you want to use your car for. You dont just throw upgraded suspension pieces on your car and hope it works well with the remaining stock Suspension. It has to be tuned accordingly for it to work to your liking..
Advertisement
MBGRAM-2
Advertisement
