Driveline Clunk after Cradle Lockout Kit/Supporting Mods
bluestar
Illinois
2018 Kona Blue Mustang GT
So I had some suspension work done to the my Mustang. I added RTR lowering Springs, Steeda Cradle Alignment Bushings, BMR Cradle Lockout Kit and, Vertical Links, and BMR Differential Bushings. Then had the car aligned.
Since adding said mods I'm getting a lot of driveline clunking. Doesn't happen when the car is under WOT or cruising on the highway, but more so at lower speeds. It's worse if when the trans downshifts if I'm driving and have to slow quickly.
Called the shop that did the install and he basically said that all of the bushings working in tandem eliminate a lot of the slack the stock softer bushings soaked up. Having the car looked at next week. Any input would be appreciated. Really not happy driving it like this.
GregO
Illinois
S550 GTPP
First thing to do is remove the BMR Differential Bushings.
Level 1 or Level 2 BMR lockout ?
bluestar
bluestar
Illinois
Remove them and replace with stock?
Level 1.
GregO
Illinois
S550 GTPP
Level 1.
Run the OEM Diff mount setup as Ford designed it. You won’t regret going back.
Personally, I like the BMR Level 1 kit combined with Steeda alignment dowels.
bluestar
bluestar
Illinois
Thanks for the advice. :)
CORNYOTE
Oklahoma
Alex
2019 GT
Experiencing the same thing, but man I can't imagine going back to the stock diff bushings. Especially with almost 900whp.
moffetts
San Mateo CA
Black Whippled 2015 GT PP
It’s a tall order to make a 900 hp car behave like stock, even temporarily. If you want big power, you have to sacrifice something.
shogun32
Northern VA
if you do go back to OE diff bushings, make *SURE* you use one of the upgrade bolt kits that do a better (if not perfect) job of shimming out the rear fastener slop.
I wonder if there is any merit to turning down the hard bushing material and adding a couple of D70'ish o-rings
jacknifetoaswan
Charleston, SC
Are you sure it's not the driver's side halfshaft?
JR
CORNYOTE
Oklahoma
Alex
2019 GT
My clunk is 100% from the passenger side. Sounds like the halfshaft to me. like some play in it.
Maxlab
2017 Mustang GT, 2009 F150 Lariat
The noise is common with the differential bushing lockout, I get the same noise. After adding an aftermarket exhaust and headers, I can barely here it now. You will get used to it.
CORNYOTE
Oklahoma
Alex
2019 GT
I have headers, xpipe and active exhaust, but i still feel the clank even if i don’t hear it. Annoying but not as annoying as the viking shock squeak lol.
