Drive mode toggles?
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
I know it sounds strange, but in sport & track mode the manual seems to shift smoother to me.
lew
lew
illinois
lew
19 GT, 23 STX 4wd. TT, 19 BMW X4 M40i, 15 800r
Possibly due to synchronization.
I know it's a bit off topic but since you have a 19 Bullit.
What gear have you found that hits top speed?
I know my V6 tops out in 5th gear 6th gear will hold the speed while dropping the RPM's with no gain in top end.
Timeless
South Carolina
2024 Grand Highlander Hybrid Max Limited
OK no one has mentioned this so...
Does the track or sport mode change the speed limiter settings?
Will 6th gear be allowed to reach redline? in any modes?
Speed limiter can only be removed with aftermarket tune.
lew
lew
illinois
lew
Kinda what I thought. However removal and alteration are two different scenarios. The Bullit has a top speed that is 8 mph above any GT including those equipped with the A10. I was thinking perhaps Sport or Track mode on 6sp. would alter speed limitations. Something in the Bullit mapping programs allows this model a higher top end even though it has 373 final drive. The additional 20 horses shouldn't change speed limits.
Thoughts?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Thoughts?
The GTs are probably governed too (based on tires), just another point to help sell the Bullitt.
Drive modes don't affect the limiter though, on the V6 it is just straight 121. Once you tune (and upgrade tires!), you can easily get to 140. I haven't pushed mine further than that because the road becomes much shorter at those speeds.
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
Thoughts?
I might be wrong on this, but with the tune in the Bullit they have proobably moved the redline a bit higher over the regular GT thus giving it a bit more of a top speed. The cars are factory hard coded at 183mph, so even with limiters removed and tunes adjusted, the factory ECU will limit it to that speed.
lew
lew
illinois
lew
I wonder what RPMs are at 183mph?
Bedista
2019 DHG Mustang Bullitt K-3298
How do i make “My mode” the default mode when i start the car? it always defaultto normal and I can’t figure how to adjust this. Thanks!
CAL Captain
Arroyo Grande, CA
2019 Bullitt Mustang
Muscle memory: Your finger goes from the start button to the far-right lever and 2 blips up.
2slow
Austin texas
Albert
2018 mustang gt
The only change in throttle response between modes is going from wet/ cold mode to any other mode. Otherwise, I don’t sense any difference in mine.
Hooch180
Europe, Poland, Silesian Agglomeration
Maciej
Ford Mustang GT 2019 5.0 (EU)
Don't have mine yet. Can you change settings in default drive modes? For example I would like not to change throttle response in Sport mode but have firmer suspension and steering.
Mikthehun1
With the a10, I definitely feel it. The transmission also behaves way differently. Of course, our butt-dynos could just be calibrated differently.
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
If you don't have a noticeable increase in throttle response going from Normal to Sport you might want to take your car in for service.That's one of the main changes between the 2 modes.
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
There isn't a way to do that. It'll start in Normal no matter what you do.
You can change the steering feel in Normal (default) mode. Can't get the firmer suspension w/o changing modes. There's no way to change throttle response w/o changing modes unless you go aftermarket.
For some reason in the 18+ you can no longer be in Sport mode and change the steering feel. It stays in Sport for all modes except Normal & Wet.
