Does anyone else find it difficult to shift into 2nd gear sometimes?
dasaf
Orange County
2015 Ecoboost 6spd Manual
Sometimes when I'm either downshifting or upshifting into second gear there is an extreme amount of resistance while trying to get it into gear. I have to pull considerably harder on the shifter to get it into gear and it just feels so wrong...
There is also a slight whirring sound when im driving coming through from the shifter. I don't know what's up. Any insight would be very helpful. Thanks.
notstok5.0
IG: notstok5.0
Eastern PA
www.mustang6g.com
Eric
2015 Ingot GT
Yup, sometimes I'll notice it and pull back then try again. It usually happens when I'm commuting and shifting at <2K RPM.
dasaf
dasaf
Orange County
It's just so odd, I've never had something like that in any of my other cars. It also seems random. It's not specific to any RPM it just sometimes is smooth as silk, while other times it takes a lot of effort. Weird.
notstok5.0
IG: notstok5.0
Eastern PA
www.mustang6g.com
Eric
2015 Ingot GT
Yea, it is not consistent nor does it happen every day. I just notice it more when I'm lazy shifting to/from work.
ForTehNguyen
Houston, Texas
15 GT
are you stock? aftermarket shifters pretty much eliminate this problem
ForTehNguyen
Houston, Texas
15 GT
I noticed the 2nd gear resistance on my stock shifter too, which didnt last long when I swapped out :D
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
BmacIL
Enginerd
Naperville, IL
More than stock but not bad. You could go with one of the polyurethane ones if you're sensitive to NVH.
This is one of those things where I would really like to hear it in someone else's car. I don't care as much about vibration in the shifter as much as noise.
dasaf
dasaf
Orange County
I'm just really hoping it's not anything serious. Ngyuen which shifter would you recommend?
paul123
'16 Mustang GT
don't do that.
paul123
'16 Mustang GT
one article I read said that downshifts loads up the syncs much more than an upshift. So you might be somewhat more aggressive in upshifts, but a downshift should always be minimal effort. If its not, then avoid doing that
dasaf
dasaf
Orange County
Paul, even if I let go to try and re-shift it requires the same amount of effort. I get what you mean though. heh.
