Do New TPMS Sensors Require Programing?
Shawn 94 GT
SC
2019 Magnetic Mustang GT PP1 A10
Hi all,
I am getting ready to install a new wheel and tire combo on my ‘17 GT. I will be installing new wheels, tires, and new TPMS sensors. I will be taking nothing from the current wheel and tire package. I have seen conflicting info as far as having to program the new TPMS sensor to the car.
I was under the impression that I would have to program the TPMS sensors to the car with the Ford Performance tool. However, I have seen numerous post, that say you can just install the sensors, and drive for 8-10 miles and they will sync up with the car. This is news to me, and doesn’t seem like it would be correct. Please point me in the right direction, so I know what to order before the tires get here next Wednesday.
Thanks,
Shawn
Joe B.
Westmont, Il.
2017 Mustang V6 coupe
I rotated my tires the other day and they synced up on their own which surprised me, verified by over filling a tire. So if they are OE type sensors, I would say there is a good probability you will be OK.
Shawn 94 GT
Shawn 94 GT
SC
They will be o.e ford sensors.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
No programming necessary, if they are Ford sensors they sync automatically.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Generally they aync fine on their own. After 100-200 miles it will throw an error up on the screen if it had any issues.
I had trouble with an aftermarket set because the original tires were stacked in the corner of the garage, which I think confused the car, so I keep the $30 training tool handy. Issues are uncommon tho for most people.
2015RS1
Tampa, FL
2015 Roush Stage 1
I am new to TPMS sensors as my last mustang was an 01 GT...I just scraped a curb bad and basically destroyed both of my passenger side 20" Quicksilver wheels on my Roush:doh:The tires only have 10K miles on them so I'm just buying two new wheels ($500 a piece!) Since I'm just having the old tires mounted on the new wheels the tpms sensors will just transfer with nothing else to do right? The TPMS sensors are attached to the valve stems inside the tires? Sorry for the dumb question but this is the first vehicle I've ever owned that has these sensors.
Blue Moon
Maine, or eastern Canada
Pete
17 Ecoboost Perform Pack Std
I bought the little pushbutton remote tool, and I've never needed it. Just swap the wheels, drive a few minutes, and the numbers pop up when I check the pressure. Easy as pie.
BluePonyGT
Seattle, WA
Corey
2017 Grabber Blue GT Premium 6MT
I have mounted wheels/tires coming from Need4SpeedMotors here in a few weeks with the sensors installed. Their line to me was that they would sync up on their own once I had them mounted and spun around for a bit.
2015RS1
Tampa, FL
2015 Roush Stage 1
Good to hear, since I already have the sensors in my current tires new wheels are all I need, ordering now. When I go to a shop to have the tires remounted, how do you guys tell the shop to balance the tires? I always tell them that they better not balance on the outside or I'll lose it lol, they've always used weights on the inside of the wheel but isn't it just as effective if they balance on the INSIDE of the wheel? That way you don't see anything, how about you guys?
Shawn 94 GT
Shawn 94 GT
SC
A7X
Toronto
2017 GT Premium Black Silver Stripes
Timely topic. I got new wheels/tires/TPMS and it's been 20+ miles and no syncing up yet. ope they do tomorrow
Dominant1
Dr Frankenstang
if they are not Ford oem you will have to use a programming tool...
  • Like
Reactions: A7X
gbgreen
Central NJ
Gerry
2016 Ruby Red Manual V6 Mustang Coupe
A couple things for 2015RS1:
1) Make sure you check over those tires really well (inside as well as outside), and request that the tire shop do the same. If you hit the curb hard enough to require new wheels, the construction of the tires may be compromised. I believe there can be internal damage even if none is apparent to the naked eye, so you should keep an eye on those tires from now on.
2) If the tire shop knows what they're doing, they should know to mount weights on the inside of high performance alloy wheels. For wheels that expensive, make sure you take it to a respected shop. If you're getting them through Tire Rack, you may want to use one of their recommended local shops (if you don't have one in mind). You may even be able to get the name of a good shop from this message board (either listed vendors, or put up a post on one of the local boards).
For anyone getting new wheels, I would recommend just getting the tool. It's less than $35 the last I checked, It takes only a minute or two to sync up, and you know that it's done (no waiting for an unknown number of miles to re-sync). This goes double if you're going to be swapping wheels on a regular basis (switching seasonally or even more frequently if you are going to track the car). Just some friendly advice...
A7X
Toronto
That could be the issue. The tire shop said to bring the car back if they don't sync up. They did have a programming tool
I'm sure it will get sorted out but frustrating until it does
