Programing Taillights Mustang S550
Little Diva
Germany
Ralf
Mustang s550
Does anyone have a forscan coding of the US taillights on running flashing.?
Chef jpd
Brooklyn, NY
What do you mean by " running flashing" ?
Little Diva
Little Diva
Germany
Ralf
Mustang s550
Hi,
Hi, I've read that US Mustangs sequential flashing can be activated or deactivated. Since it is forbidden here in Germany in the Mustang and the taillights are changed accordingly. So they are cut open and glued cheap leds. Have new US lamps but the sequence does not work.
Hooch180
Europe, Poland, Silesian Agglomeration
Maciej
Ford Mustang GT 2019 5.0 (EU)
You can try this:
Lights - Sequential Turn Signal Enable/Disable (all 3 bars light up at same time if disabled)
BCMB
7B7-03-01 x?xx xxxx - Change ? To: 0 - Disable (off), 1 - Enable (on-default)
I'm from Poland and I would also like to buy the US taillights.
1st Pony
Auckland
Peter
2019 Mustang GT
You can try this:Lights - Sequential Turn Signal Enable/Disable (all 3 bars light up at same time if disabled) BCMB 7B7-03-01 x?xx xxxx - Change ? To: 0 - Disable (off), 1 - Enable (on-default)
Well that was interesting. How does one make that happen?
Hooch180
Maciej
You need to modify that config address location using forscan. But I guess that it will not work in EU car with US headlights. But can be probably used to enable/disable sequential lights in US car with US headlights.
There are other topic about sequential lights for EU version of car.
Little Diva
Little Diva
Germany
Ralf
Mustang s550
You can try this:
BCMB
Ok, it's US model.
