DIY Strut Tower Opening With Steeda Cutting Tool
THX 138
Brownsburg, IN
2016 GT350 Track Pack, 2002 Porsche Boxster S 3.8L
I bought the Steeda cutting tool over the winter and have been waiting for the weather to warm up before tackling this project. It's the first weekend of spring, and my first track weekend this year is in 4 weeks, so time to get it done.
I wanted to keep the metal shavings in the engine compartment--and near the Vorshlag camber plates' spherical bearing--to a minimum, so I approached it like a surgical procedure. One thing I learned after doing the driver's side was that just stuffing a rag inside the opening wasn't sufficient to keep the metal shavings out. So on the passenger side, I covered the camber plate itself in duct tape.
Next I took an old sheet and cut a hole in it to keep the shavings out of the rest of the engine compartment, securing it in place with the three upright bolts and more duct tape, with a small rag stuffed inside the opening to absorb some of the cutting oil.
Apply some cutting oil to the surface liberally, and set your drill to a SLOW speed. My Skil drill goes up to 800 RPM, with 12 speed increments. I started with the 2nd-slowest setting, and never got above the 4th slowest. Those settings were PLENTY fast for this job, and prevented damage to the hole saw. (Even after doing both sides, it's still sharp, and I only lost 1 tooth.) Go slow, and FREQUENTLY add thread cutting oil to the channel as you cut.
I used a Dremel with a deburring tool to remove the sharp edges of the hole, then went over it again with a sanding disk attachment. I used a Shop-Vac to pick up the big shavings after removing the sheet.
Despite my best efforts, I still ended up with metal shavings on the camber plate itself, so I carefully used toothpicks and cotton swabs soaked in isopropyl alcohol to remove them.
All in all, this turned out better than I was expecting, and I didn't run into any problems. Taking a break now, then I'll go back and prime & paint the exposed metal surfaces. Hope this tutorial is helpful to somebody.
pilotgore
US
A bunch
It certainly was! Nice write up!
THX 138
THX 138
Brownsburg, IN
Thanks. The saw should still be sharp enough for you to use on your car, and I can give you some of the cutting oil to use as well. I have plenty left. :thumbsup:
pilotgore
US
A bunch
Awesome, I appreciate it! Just let me know when would be a good time to come grab it over the next few weeks.
Epiphany
Global
I like to disassemble things.
So how much negative camber will you be shooting for?
THX 138
THX 138
Brownsburg, IN
Nothing too crazy... Somewhere around -2.5 to -3.0 degrees? With the Vorshlag plates, and leaving a conservative 1/8 to 1/4" distance from the strut top to the strut opening, I was getting around -2.2 degrees or so. Really just did this to maintain a decent distance when I go beyond that.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
pilotgore
US
A bunch
All of it!
How much are you currently running? As the local track degenerate, I'm guessing you've tested several different setups.... what has your experience been with less/more? I seem to recall someone else saying 3.2-3.4 is at the point of diminishing returns.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
It's going to depend a lot on tires, suspension (primarily the bushings), track, and of course, driver skill :) I've seen -3.7 be necessary and also less then -3. I currently run -3.1/-3.2 the most, but I do change it up depending on tires and track. A pyrometer is absolutely key, IMHO
pilotgore
US
A bunch
Have a recommendation for a specific pyrometer, or anything off Amazon should work?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
This is the one I have. Simple, works every time, and has a nice big display. I can store it in the car and take readings in hot pits if I'm by myself. The bigger ones with memories are definitely nice, but not portable.
pilotgore
US
A bunch
Link?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
