Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
Can you elaborate on the spacer issue with the starter? I'm about to start my gen5 install with BMR mounts.I'm not done yet, but from my test fit you can use the strut tower brace with the 5 gen whipple. I lowered the engine using the BMR upper motor mounts so that I could retain the lower portion for NVH purposes. These mounts are made for a GT though so you will need a spacer to properly mount your starter. After taking off the insulation pad under the hood, I'm left with 11mm of play room from what I've come to. More to come.
Out of curiosity, has anyone used a reflective insulation before? I was thinking about putting that under the hood to help off set some of the direct heat off possible.
