Direct swap amp for Shaker Pro sub?
Hilfloskind
Murfreesboro TN
Brian
2018 Ford Ecoboost Convertible - Kona Blue
I just ordered an RF Punch P3SD2-8 sub to swap into my existing Shaker Pro sub enclosure. My initial plan was to have a custom fab enclosure built for my Orion XTR 12" sub and Kenwood amp, but the prospects of finding anything remotely small enough not to wipe out a majority of my limited convertible trunk space were pretty low.
That being said, I've decided to accept the lack of 12" sub depth/power and work with the factory system as best as I can. I'm replacing the front 6.5's with Powerbass components and the 3.5's with Infinity Reference 3022cfx's, while retaining the stock amp. I may either swap the tweeters with the PB supplied ones using inline bass blockers (vs the supplied crossovers) or simply disconnect the tweeters altogether since the Infinity ones are coaxials.
That being said, I am curious if anyone has any experience doing a direct swap for the Shaker Pro sub amp itself. I don't mean routing from something in the trunk or spare tire area, but actually swapping in a mini amp in the existing location and reusing the factory wiring without running new power lines. I saw some very low profile mono amps online and there seems to be quite a few options that look like they may get the job done. I simply want to maximize the output of the Punch sub without giving up any space in the trunk.
Ideas?
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Hilfloskind
Murfreesboro TN
Brian
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I was looking at that exact model today. My question is: can I reuse the existing wiring to the factory sub or do I need to rewire anything? Sounds like the fuse rating is identical, so I'm guessing this might be plug and play.
Any idea?
Thanks for helping on this, by the way!
From a quick glance at the spec page for the PBR300X1, it delivers 300W into a single 1 ohm load. You will need to make sure you wire the dual voice coil sub for 1 ohm mono operation. Should work just fine. You will need to cut or splice wires from the factory harness to the new amp. Add some polyfil pillow stuffing to the box (don't over stuff). Should be a piece of cake.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Just noticed this amp needs a +12V remote turn on. Our mustangs use 6V or something. So you'll need a relay or something to give you a 12V remote turn-on.
Hilfloskind
Murfreesboro TN
Brian
Hilfloskind
Murfreesboro TN
Brian
Would this model be a better option perhaps? It's not a mono amp and appears that it would work with a dual voice coil sub:
https://www.rockfordfosgate.com/products/details/pbr300x2/
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Hilfloskind
Murfreesboro TN
Brian
This one or the mono amp WILL work you just need to wire them differently. If you go with the dual channel amp, you will get 160W to each voice coil as opposed to 150W per coil with the mono amp. So there is that benefit.
In either case, as long as I use the 12v converter you linked, I should be able to use the existing factory power and signal wiring to the OEM amp, correct?
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I see no reason why it wouldn't work.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
dgreene
Johnstown, PA
Dustin
2019 Mustang EcoBoost Premium Convertible
Was line signal from original harness (OEM) loud enough? What colors were line signal wires? Violet/Green+, Green/White - ?
