Difficulty with 2nd gear downshift and reverse (manual)
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
2020 Bullitt with an MT-82 here bought new and had this exact "issue" from the get go. I'm currently at 54k km. Fresh tranny fluid (Ravenol MTF-2) made no difference. I guess it's just a feature 🤷‍♂️
Its not a feature... its a common behavior for Manual Transmission cars (at least for all the manuals I have had)....
First Stang
2023 Mustang Mach1
Check to make sure your seat position allows you to fully depress the clutch. At 4500mi, I find that I have to put extra oomph when downshifting to second. Reverse at times needs a clutch release and reapply to engage. No gear noise/vibration though.
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1, FJG, manual
change the fluid out to BG syncro shift 2. OP mustang has a kit with the correct amount of oil and a hand pump. When I switched all notchyness in every gear change went away.
I only found a kit for MT-82, with 2.8 litres of oil. I believe there is 3.5 litres in Tremec.
xcm77
EU
C
Bullitt 2020
