Depressurize fuel system
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
What is the best way to depressurize the fuel system ti change injectors?
Thank you,
CH
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Lift the back seat cushion, disconnect fuel pump electrical connection on drivers side (can’t miss it), start car and it will stall. Reconnect everything and system is depressurized till your next start.
ahl395
Allan
You can also pull the fuse in the fuse box under the hood, which is a bit easier.
Then of course start it and it will die. At that point the lines have no pressure. Remember it will still drip and be in the fuel rail when you remove it though.
FIVE_LITER
Indiana
16 GT PP Competition Orange
Wrap a rag around the fuel rail fitting and disconnect it...
CEHollier
CEHollier
Prairieville, La.
Charles
Thank you gentlemen. Will this cause it to throw a code?
Kinjirra
I R Slow
Chapel Hill, TN
Brian
16 Ruby Red GT W/PP, 401a
I suggest after it dies the first time you try to start it a few more times...we have a high pressure system so it wont fire if it drops too low but it may still have pressure. Also keep it unhooked until your ready to start it back up... Better safe then sorry right
CEHollier
CEHollier
Prairieville, La.
Charles
Thank all for the helpful responses. I think pulling fuse 49 and cranking several times will be the easiest way to purge the line.
Xander33
Connecticut
Jake
2019 GT PP1 A10
Reviving for stupid question. I have my interior completely removed for an audio install and to have all the dash trim and chrome rings painted. Because of this, all electronics are out, start button etc. I figured I may as well do my CJ swap, fuel rails etc while the car is apart, but now I have a dilemma...can’t depressurize the fuel system the traditional way to get the injectors out and rails off. Any ideas gentlemen??
NGOT8R
Adrian
2019 Bullitt
When I disconnected the fuel line at the rails on my 2019 Bullitt for my nitrous install, I didn’t have to do anything special and no fuel sprayed out at all. The car had sat for a couple weeks prior to me disconnecting the fitting. I did have shop rags in place just in case, but they weren’t needed.
Xander33
Connecticut
Jake
2019 GT PP1 A10
Awesome! Mines been sitting for weeks. I’m going to head out there and start pulling it apart. Thanks!
Brian@BMVK
Illinois
2015 GT - Sold
If it's been sitting it will have lost pressure and bled back to the tank. Some will drip out but not spray.
V8_MOTOR
Nottingham, UK
MY17 S550 Mustang GT (EURO)
This. Close thread šŸ¤˜šŸ½
