Delivery Data! 1.86g, 5.1m, 1:44min
WCRookie99
Illinois
G
2021 Mach 1, 2007 FR500C, 2022 LH5
Not complaining, just observation of delivery data. The Boys at Flat Rock can bed the brakes and turn right! (FYI, car was off that’s why the engine light is on)
ChemEng44
St Louis
2025 F-Pace SVR, 2019 600lt, 2020 GT500 CFTP, 2026 CT5v Blackwing
Dang, looks like a quick launch, hard brake, and hard right turn........must not be Nascar fans.
Performance nut
TX
2018 Mustang GT A10
Talk about one hell of a ride. My first question wouldn't be why they did it but how they did it 😅
WCRookie99
WCRookie99
Illinois
G
Funny stuff, they will from now on reset the Data! 1.86g under Braking is huge.
doritoking
PA
2021 mach 1 with handling package
Mine had the same braking and right turn, so did the car I was driving at the mach 1 track attack!
PBM457
Close to the border
Paxton
Jeep Wrangler, Ford F-250 Tremor , Mach 1 #2510
they Are all relatively similar. Here’s mine.
DrumReaper
South East
Makes we wonder if the units are tested from the manufacturer prior to shipping and dash install…
WD Pro
United Kingdom
Lime GT
Over in normal GT world they are known to show exceptionally high values until the first owner reset :like:
WD :like:
Leeroy
UK, North Yorks
Lee
Mach1 FJG manual/'65 289 Coupe
Mine had similar readings when I picked it up…this explains it then!
WCRookie99
WCRookie99
Illinois
G
Right, so I don’t think it’s a manufacturer of the digital dash, rather it’s a Ford test driver actually putting the M1 through an aggressive short test. As braking is ABS computer limited so you can get fairly consistent g when you’re use to slamming on them.
Plus I replaced my front brake pads and there’s a lot of brake dust for 5.1miles
The 1:44 hours of run time seems ok I guess.
Yep, issue solved.
WD Pro
United Kingdom
Lime GT
Most super cars can’t beat 1.25g under braking but you believe the Mach 1 consistently does 1.86 on its factory test drive … ?
WD :like:
WCRookie99
WCRookie99
Illinois
G
WD :like:
Hum yep, check that, 1.86g is nuts. I’m starting to believe it’s a bench test.
Just looked up my Data from the Boss R:
Max right 1.41g
Max left 1.55g
Max Braking .97g
That’s on a legit lap at Road America
sakman84
CA
Adam
2021 Mach 1 Premium. 6MT, Blue, upgraded wheels
Mine showed very similar values on the same sides. I also believe this is some type of bench test.
1.79 and 1.86
