EFI
- May 19, 2015
- Masshole central
- 5.Br0
There's no reason to believe it's not accurate, unless the sensor itself is malfunctioning. Unlike oil temperature for example which is an inferred value based on other factors, the cylinder head temperature is read by a sensor directly in the cylinder head. While there may be variation from one head to the other and from the front to the back of the head based on coolant flow, whatever the temp is being displayed should be exactly the temp of the actual part.Gotta wonder how accurate the temp is, too. I'm sure there's a few degrees variance here and there. Mine has gotten up between 210° and 220° if I've been driving for a while (everything is completely warmed up) and end up in a situation where the car has to sit for a few minutes. If I blast the heat the temp reading will drop down to about 207. Car nornally bounces between 200° to 203° when cruising, even during the winter, and only drops to 198 if the heater is on.
