Constant clunking from swaybar endlinks?
tj@steeda
Timothy
Please send me an email to [email protected] - I will introduce you to our lead tech for install/maintenance support.
Best Regards,
TJ
xl_cheese
Wes
2017 GT Premium
Wondering if you could fine a parking lot somewhere that has an elevated edge with no curb. Then drive your car right up to the edge. Put the parking brake on and access the endlinks from under the front.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Just jack up the car, remove the tire and tighten the link bolts. They are not under tension.
DougS550
Fishers, Indiana
Doug
Have the Steeda adjustable ones and I tightened them down and now they’re clinking again. Going over bumps. It’s driving me nuts.
Anything else I should look for?
Hi. Did you sit your car on the ground to neutralise the suspension/bars prior to tightening the end links? (I sat my car on 10" boards so I had room to crawl under to adjust) I put 250 lbs of weight on my drivers seat to simulate my weight while driving. I torqued the jam nuts and applied Blue Loctite. Good Luck
robvas
MI
2011 GT
If you are working like normal people without a lift and what not. You just need to get the car weight on the suspension.
You don't need to. It's not that kind of bushing.
LFmustangGT
L
2007 Mustang GT
Had the same problem on my Ford. Took it in for repair and came back doing exactly what you describe. Decided to keep driving since it wasn't hurting nobody, except like you said over bumps and potholes. Finally, heard about about a shop that was good at these sort of nuisances. That guy said it was those links on the swaybar. Seems the first didn't know what he was doing, or was toying around with the rear end and left loose ends all over the place. Paid the new guy and still driving it like racehorse.
