jwt
Been noodling this for a while in idle moments of visiting the nothing box.
For the sake of argument your car is sitting for a few days at -15 C (5 F) nicely cold soaked. You are about to start it and want to minimize any start up wear. you have 2 options only.
1. Normal start, hit the start button , engine fires to life, you let it idle a suitable amount of time before driving off.
2. Hold the accelerator pedal down, thus engaging flood clear mode and the engine does not fire for say 20 seconds giving the oil pump time to pressurize before ignition forces come in to play. You again allow the engine to idle a suitable amount of time before driving off.
For the purposes of this thought experiment we will not use block heaters, change oils, store the car somewhere warm etc etc. The battery is infinitely charged so cold cranking is assumed to be flawless. It's a gasoline engine and reasonably modern lets say 10 years or younger. Just the two options above. Amount of time to idle before driving off is the same in both cases and dependent on your opinions of saving the planet versus crashing the car due to a frozen over windscreen.
Which option is most likely to minimize start up wear?
