Coilovers?
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
Bullit69
Manny
19 Mustang GT Premium Convertible
Thank you so much for the help Biggsy. Really I’m willing to spend big money.
I’ve gone down the rabbit hole, I’ve looked at Ohlines, Fortune Auto just so many choices. It drives me nuts. If someone could other me just what I want, I want it to be comfortable and handle great.
Then the complexity of setting up the coil overs…. And convenience. Some have the dial readily available, others have to be removed to access the rebound dampener.
I looked at KW, they have several options….
I was surprised other well seasoned members have had issues setting up their coil overs. I’ve read this whole thread… šŸ˜‚ a few times.
I don’t mind dropping the coin, fixing to go on vacation either Colorado or the Pacific Coast Highway, my new top should be installed this week.
If not I’ll just buy some shocks/ struts for now.
CobaltFilly
NorCal Valley
instagram.com
Davis
2016 3.7L V6 Mustang
Is this a daily driver as well? If so I suggest the Steeda setup (look in my signature). I talked to them about what would be best for a comfort ride and for some track use and this is what they told me works and it does wonders.
Just get adjustable shocks and struts (I went non-adjust because I want to set and forget).
or spend the really big coin and go with a $7k external chamber setup like a GT4 car. šŸ‘ŒšŸ«¶
Edit: I am a sucker for comfort after my youth of building a track 1995 Honda Accord EX coupe running BC racing coilovers…not a fan of the stiffness on streets daily driving 🫣
Edit 2: The steeda setup we use is GREAT for both 17x9.5 (super plush on street, meh on course), and 19x11 square (tiny bounce on street only in bad areas, REALLY smexy on the course).
Edit 3: If you really need to know the absolute BEST on something, may I suggest talking to @NightmareMoon. Has been helping me along my journey (and hopefully will continue to!)
shogun32
Northern VA
Ohlins. I own fortune auto. Not near good enough. The ohlins is a solid home run. I got a chance to drive @Bluemustang car. Excellent kit!
Accept no pretenders.
I've run several Steeda setups as well. Sport progressive springs are too low. Rear dual rate springs are probably not best way forward. Proactive arent damped enough in rebound. Proaction adjust are pretty good - best of what they have.
But Bilstein take the cake in the best balance of perf for price but you need to not stray wildly from stock spring rates.
Biggsy
MD
Warren
I think he is saying why would you want it. I think there are handling benefits to more rake. If you have a front splitter where the angle isn’t adjustable you can increase rake for downforce. Also it changes over/understeer
WItoTX
Houston
Kyle
'17 GT350
My point was more, the rears of these cars sit way too high stock. I thought you were saying the ohlins kit made it worse. But it sounds like it's giving the stance that is exactly what the car needs.
I know I've tweaked mine and the front wheel gap is more than the front, but also it allows for so much more in the corners from these cars.so maybe we are talking the same thing?
Biggsy
MD
Warren
Lol I was loud and wrong. My apologies
WItoTX
Houston
Kyle
'17 GT350
Lotta things going on there...what tires did you have, and did you go to that you gained a full inch on the front?
WItoTX
Houston
Kyle
'17 GT350
Have you posted a photo of your car with the new coil overs??? I haven't checked TMO in a while, probably should look there.
Biggsy
MD
Warren
Not yet. Still in the install process. I just know that on 18ā€ wheels, the rule of thumb has been 24ā€ from bottom of the wheel to fender as the starting point and then corner balance (if you want) from there. That applies to all corners. Maybe 24.25ā€ in the rear for more rake. Hoping to have everything wrapped up this weekend.
WItoTX
Houston
Kyle
'17 GT350
My car, not one centercap to fender is exactly the same. But my car is corner balanced. Basically right at 50.1 / 49.9.
I wouldn't mess with ride height until I had my car corner balanced personally.
