Clutch pedal spring
Julian
2017 Lincoln MKZ 3.0t, 2008 Infiniti G35x
Would anyone know if replacing the strong,OEM clutch pedal spring with a softer spring would void the Ford warranty?
NGOT8R
Adrian
2019 Bullitt
I wouldn’t worry about that at all if I were you. If you ever have to take it in for warranty work, just put the factory one back in until the warranty work is complete and then switch back to the lighter spring.
MattMPA
SE PA
2022 GT, 2016 Interceptor Utility, 2005 Excursion
It won't void the car's warranty. The Magneson-Moss act prevents this. If the aftermarket part is proven to have caused another factory part to fail...that is the only part for which the factory can void the warranty. Example, after market alarm shorts and damages electronics. Those electronics may no longer be covered, but the rest of the car is.
Put the spring in - enjoy the car.
Transylvanian Bat
Julian
Thank you all for the advice.
2fast2focus
NY
2022 Mustang Mach 1
I installed the steeda spring in my car today and Tbh, I don’t think the dealer would have any idea that you swapped the spring. I had the spring in my Focus RS and took it in for work a few times without issues. I think you’ll be safe.
Rapid Red
Woodstock GA
Greg
The simple, straight answer is NO..
KingKona
Virginia
Shlomo
2019 GT
Vlad ČšepeČ™.
daSNAK3
Cary, IL
Jake
2021 GT
Is the spring perch kit worth getting while doing the spring?
NGOT8R
Adrian
2019 Bullitt
I don’t know the correct answer to that question, but I did both. I assumed that if Steeda designed a new perch, it would have been because they felt it was stronger than the factory perch and would also compliment their spring.
tj@steeda
Timothy
We offered this solution because a replacement perch through your local dealer is almost 2x as much - since you have to purchase the full kit.
Its peace of mind that you have 2x chances to get it right (re-using the OE or moving to our replacement unit) because it gets a little tricky to install.
Hope that helps!
TJ
MACHtobers Very Own
Hampton Roads, Virginia
2022 Mustang MACH 1
I would do the perch. I was very careful and my OEM unit cracked on way out. Just do it all at once for peace of mind.
I also was crazy happy with the investment.
David Schmidt
North Carolina
David
2018 GT Premium MT82 PP1 401A
I did the spring and the perch (I broke my OEM perch in the process IIRC). I had my car in for a throttle body replacement not long ago, and the tech noticed the different pedal feel and asked me about it. Not in a bad way, just "hey, did you put in a new clutch?"
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
