John S
- Jul 26, 2022
- Novi, Michigan
- John
- 2022 Mach 1 HP
So I thought I'd be cleaver and interrupt the simple two-wire clutch pedal position switch with a kill switch to prevent an amateur from stealing my car. ( It actually prevented two previous theft attempts with other cars.) However, unlike the historical safety function of this position switch used on just about every car with a manual transmission, it no longer serves a purpose on my Mach 1 other than illuminating the green light on the starter button when the clutch is fully depressed. You can remove the switch and it has no bearing on starting the car, it's the clutch apply rod position switch (4-wire connector that's part of the same clutch pedal harness) that communicates with the vehicle's computer(s) to allow the car to start. This change in function isn't described in the service manual or wiring diagram.
