Checking the Oil
TomcatDriver
Mojave Desert
2017 GT350 Magnetic w/black stripes
I know this topic has been covered more than once, but rather than resurrecting some very old thread that doesn't quite match I started a new one. I've checked the oil in my GT350 pretty religiously at least once a week or so, usually on weekends or fill-ups. I don't wait for drain-back on fill-ups but it's always been in the hashed region. Last time I checked it hot with about a 20 minute drain-back it was about the middle of the hashes. I checked it cold yesterday and it was below the hashes. This concerned and confused me since I had not driven it much since my previous hot-check. I added about 3/4 quart to near the top of the hashes then drove it a while. First quick check (hot, no drainback) and it was above the top of the hashes. After sitting 15 minutes, went and checked again and it was still above the hashes.
So, why would it indicate that much lower cold than hot? Was I hallucinating the low cold reading?
JAJ
Vancouver BC
2016 GT350 Track Pack
Oil expands when it's heated, and unless the engine and oil pan also expand, you'll get higher readings hot than cold.
The upper "full" mark is actually the hole above the hashes, so if you're still below that then you're not over-filled.
MrCincinnati
Cincinnati
2017 GT350R
What the other guy said about hot vs cold. Be careful with consistency when checking the oil. I try to always check it in the same location (same spot at my home) to ensure consistent readings. Also per manual and as you’ve now discovered - wait 15min before checking.
A quick check when cold to make sure you’re not running dry is fine - but you should not add oil based on cold check unless the stick is actually dry.
It gets kinda old checking it all the time in this manner but it also prevents you from overfilling or running low.
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
I did an experiment once with mine. Checked when hot but did it right after shutdown and then 5 minute intervals till I reached 15 minutes. It definitely showed a level difference at the start and then end.
TomcatDriver
TomcatDriver
Mojave Desert
I knew what the manual said before this, and that's what I usually do. The usual problem is to be consistent with the drain back time. If you check immediately after turning the car off every car I have ever owned is going to read a little bit lower than after you let it sit for a few minutes, but usually you will get a bit of a high reading if you let it sit longer as more oil drains out of the engine into the pan (which is more than the thermal expansion). I've been checking oil in cars for a long time, and I have never seen that much difference between hot and cold. I'll let it settle overnight and see what it says in the morning just for reference.
TomcatDriver
TomcatDriver
Mojave Desert
Higher or lower? That is, did it go up every 5 minutes as more oil drained into the pan, or go down every 5 minutes as the oil cooled?
DCShelby
DC
Robert
It goes up as the oil drains back in the pan. Note the oil is hot and it takes quite a while to cool off 10 quarts of it. If I was really anal I’d get it hot, then check it every 5 minutes till it cooled so much the level goes down. That might take a few hours but being a geek engineer I suppose it would be interesting to record. To be super anal you could do this test at various ambient temperatures. Or I might just go drive it or take the Ducati out.
MrCincinnati
Cincinnati
2017 GT350R
I agree with the abnormal procedure for something so routine with this vehicle. I think that may be a reason why so many people are being caught out with starvation etc. For the most part the people buying these vehicles have checked the oil in a car before and prior common experiences lend to a different result set than experienced with this car. And even after reading the manual - unless you’ve been on a forum like this where owners like myself are standing up shouting CHECK YOUR OIL! Then the manual directions may even seem like a bit of CYA.. but that 15min window is critical for accuracy and owners of this vehicle are finding out the hard way what happens when it’s ignored.
After 21k miles I’m now at the point where I feel I know when I’m burning oil and when I’m not (driving style) so my oil check habits follow my driving behavior.. meanwhile I may have checked the oil on my 70k mi 392 charger twice in 70k mi between changes.
OnTrack
Fort Worth Texas
Patrick
2018 GT350 Ruby Red
Check the oil at the same exact time interval to ensure you have a consistent reading. I check mine at the 15 minute mark each time which gives me the consistent reading for fill up. I have not had to add any oil yet despite my driving style, but haven't started hitting the track fully yet. My Z06 was the same procedure on waiting 20 minutes for drain and needs to be considered vs immediately. ,
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
The 10 quart capacity in the GT350 makes a significant difference for the expansion factor, more so if you compare the change to cars with 5 or 6 quart capacities. Something you need to consider checking hot compared to cold.
JAJ
Vancouver BC
It's easy to over-think this issue. If the oil is anywhere on the hash marks when you check it, regardless of hot or cold or however long it's drained, then you're fine. If it's below the hash marks, add a half-quart.
All of the factors discussed above might make a 1/4" difference in the reading, but that doesn't matter if it's not overfilled or underfilled. Hence the "add a half-quart" solution. That won't be enough to overfill it if it isn't needed, and it'll get it into range if it is.
The only time you can't check it is when it's running.
Hack
Minneapolis
Mustang, Challenger
I always check my oil when the car is dead cold. I think it eliminates the time factor as a variable. Plus, I prefer not to work on a vehicle when it's hot.
I always had very consistent oil level readings doing it that way. The oil level was pretty much always mid-way between the dots.
galaxy
St Louis
'17 GT350
All of the factors discussed above might make a 1/4" difference in the reading, .
And to put it in perspective what JAJ said, keep in mind you're debating ounces. Literally (almost) single digit ounces between hot and cold readings. In a 2.5 gallon system. Let that sink in.
The owners manual is the owners manual right, but consistency is all that really matters. THIS works.
