Ceramic Coating Wheels and Calipers advice
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
Just purchased a set of wheels and before I mount them to tires I wanted to ceramic coat them along with the red Bullitt calipers. I decided to do it myself instead of paying a shop to do them. I see Adams has a nice product but curious if anybody else has suggestions based on experience. Thanks.
Timeless
South Carolina
2024 Grand Highlander Hybrid Max Limited
Not the only option but Pan does great videos.
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
Done it before with Black Magic....also add Ceramic Brake Pads for less dust!! My Shelby’s are ready for the CQuartz UK today...then Reload tomorrow..then mount the huge Nitto’s Tuesday or Wednesday!! Yes...custom Center Caps made!! One-off stuff!!!
fiveoboy01
Madison, WI
2017 LB GT 400A
Adam's - garbage.
Gyeon Rim Q2 or IGL Wheel are the two coatings I use on client's cars.
Be sure the wheels and barrels are thoroughly washed and decontaminated(you'll need an iron remover like Iron X) then prep wiped before coating for the best results and most longevity.
Biggsy
Biggsy
MD
Warren
Thanks for all your help guy. I greatly appreciate it!
Adam's - garbage.
Why you say that about Adams? Usually gets top reviews.
fiveoboy01
Madison, WI
2017 LB GT 400A
They make consumer products for hobbyists.
If you want a better product, look to Gyeon, IGL, GTechniq, CarPro, Meguiar's Professional Line, Rupes, Griot's BOSS Line... etc.
Adam's/Chemical Guys are mass marketed to those whom don't know any better.
Keep in mind that a better coating is 'usually' more difficult to install.
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
Adam's - garbage.
This ain’t my 1st Rodeo ! Done.....and done!!! Thanx!
Biggsy
Biggsy
MD
Warren
So question... How do you get around wheel weights not sticking after coating? Do I make sure I leave an area uncoated?
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
Should still stick like glue I would imagine?? Or...I had my wheels n tires mounted and balanced... then did the Ceramic Coating!! Easier on the wheels!!!!
Voo Doo
Surrey BC
Ric
2019 BULLITT DHG
Biggsy
Biggsy
MD
Warren
okay that makes sense. some say its better to do before you mount them but for that purpose i guess it better to do it after.
Thanks!
gnatsuM
Ontario
2019 Mustang GT
Balance before the ceramic. I made the mistake afterwards. The weights don't stick as well. Had to get one wheel re-done. The clip on weights would suffice obviously.
Biggsy
Biggsy
MD
Warren
Great. glad i asked before going on assumption
Shipey
Central PA
2019 DHG Bullitt.
Be sure the wheels and barrels are thoroughly washed and decontaminated(you'll need an iron remover like Iron X) then prep wiped before coating for the best results and most longevity.[/QUOTE]
I first used Sonax wheel cleaner, then Gyeon Iron, Gyeon Bathe, Gyeon Prep, then Gyeon Rim (which is formulated to withstand high heat).
