center bore
xcm77
EU
C
Bullitt 2020
How anal does one need to be wrt the center bore size? Would a .3mm difference make something not fit or not fit right?
GregO
Illinois
S550 GTPP
You didn’t specify + or - .3mm
For reference in the machining world a size on size bore and shaft will not slide together. Opening the bore or reducing the shaft size .0005” and things start to mate up, going to .001”-.0015” and you’ll hand fit the shaft into the bore if both objects are at the same temperature.
xcm77
xcm77
EU
C
Bullitt 2020
Ah, my bad. so the rim would be -.3mm if the cb is 70.5mm (which is what I found online).
coyote550
NY/NJ
Alex
2016 Mustang GT Premium 6MT PP1; 2020 BMW X3 M40i
The typical tolerance on a hub bore is about +/- 0.05mm. 0.3mm is like your basic filament fishing line and is a big difference in the machining world. It wont fit, at least not by hand and without causing damage.
NTXChris
North Texas
2019 PP1 GT
If it's smaller, you'll either have to look for different wheels with a compatible center bore, or you will need to find a machinist that is willing to bore the center out to the Ford specs. If it's larger, you'll need a centering ring.
Note that the hub bore is how the wheel is centered on the vehicle, not the lugs (even though they look like they should), so the fit must be exact. If the hub bore doesn't fit exactly, you will likely encounter vibration issues.
xcm77
xcm77
EU
C
Bullitt 2020
@NTXChris I guess if the hub bore is 70.5mm then the wheel bore should be something like 70.6mm to fit, right? or bigger but with rings
