Catch can vs breathers, procharged...
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Im ok with running breathers. My question is why is my driverside much dirtier then the passenger side?
Why is the sky blue? How does a posi traction work? It just does!!!!
SolarFlare
S. Fla
2015 CO GT
Bmaughan
Az
Ben
2015 procharged mustang gt
Does anyone know if the passenger side pcv check valve needs to be removed simply to run the pcv like procharger lays out in the install manual?
I have the UPR procharger catch can setup( so it just t’s the driver and passenger side together)
Would it be a good idea to remove the check valve?
Tatum337
GA
2016 GT
I have that UPR set up, if anyone is interested!
Coosawjack
Beaufort, SC
Jack
2022 Mustang GT Convertible
The passenger's side cam cover has a baffle to stop oil from entering the PCV valve and the driver's side doesn't since it is the INLET for the PCV system....so you will blow oil out the driver's side more under pressure.......just my guess??:inspect:
