Car play sync
Joker721
Henderson, NV
Jim
01 Bullitt DHG, 2020 Camry WCP TRD
Has anyone had issues with Apple car play not syncing? I have the B & O system.
MachNroll
East of Hawaii, West of Nevada
Doug
2022 Mustang Mach 1 Handling Package
Mine will sync. Then at some random time I will turn off the car, get back in later and sync is gone. I'll forget phone, re add phone, remove from bluetooth turn off phone restart Iphone. Nothing. Then two days later after driving the car it will sync and be back in business on its own.
I read on here somewhere that Apple car play and Ford Mustangs are glitchy.
NTXChris
North Texas
2019 PP1 GT
My B&O car will occasionally not connect to my phone. I find that rebooting the system fixes the issue. Also, try unlocking your phone before connecting the cable.
To reboot: press and hold the power button and the right seek button. The screen should go black and then restart with the Mustang logo. .
Joker721
Joker721
Henderson, NV
Jim
I did that a few times and nothing. I thought it was the phone but it worked in the other car I have. I will have to try it again and see
RescueLt
South Carolina
Frank
2021 Mustang Gt Convertible
When I first purchased my 21 GT, it was a year and a half old. I was having problems connecting my phone to CarPlay, connecting the car to WiFi, and using the Ford navigation. The dealer first did a reflash, which did not solve the problem. Then they replaced some module, and that fixed all the issues. Good luck, I’m sure you will get it worked out.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I rarely have this issue but its happened a few times. What has worked is using the other USB port. If that doesn't work a reboot of Sync will usually fix it.
Joker721
Joker721
Henderson, NV
Jim
Isn’t the center console the only one that plays car play though?
XSC
UK
Mustang 6g
Glitchy is the word! I have similar issues. Tried all of suggestions below, not sure which one works! Leave USB plugged in and then connect phone. I changed the lead and that seemed to help.
It always seems to work next time I use it! but a brief engine switch off does not always work.
RTFM
Atlanta, GA, USA
2022 Mach 1 premium 6MT ER
Sometimes it’s the cable that is faulty. Take that other car’s USB cable and try it in the Mustang
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
To be fair I have a 2021 Expedition and it has had a few issues not seeing my phone randomly. Then it will work amazing again. Seems to be no reasoning behind it, might just be a Carplay thing.
SCP440
Oxfordshire UK
2019 Mustang GT, Jensen Interceptor, Ford Capri 3.0 Ghia
Purchase the best cable you can, I was having trouble with mine until my son pointed out the cable I was using was an Amazon special. He picked up a decent one from his work and it has been fine even since.
Joker721
Joker721
Henderson, NV
Jim
Actually have an anker cable. Reset it 3x and it worked.
