Car feels floaty at highway speeds
VuDoo350
Utah
Nate
2018 GT350 Magnetic Metalic Track Pack
So i did a quick search and couldnt see anything. My car has stock suspension and i recently went TT. the only other thing i changed was i went to the R888R, at freeway speeds when changing lanes the car feels like its floating or like driving on a soft sidewall slick. is this normal?> What should my tire pressure be? any help would be aprreciated. the tires hook up nice, but high speed gets scary.
pilotgore
US
A bunch
I don't care what the general sentiment is towards R888R's, but I hate that tire with a passion! The hype is strong but I find it's maybe the least predicable tire I've ever used on track. Sorry.... I felt the need to rant for a moment :)
I take it zero issues prior to the tire change? Were you on Supersports before? Does changing driving modes while on the highway net a different suspension feel? I'm guessing 34-36 PSI for street use.
Fathouse installs quite a few of those tires on customers cars due to the straight line performance, they may be a better resource.
VuDoo350
VuDoo350
Utah
Nate
ya, was running the factory super sports zero issues, car felt like it was on rails. I went with the R888R as a few guys around here have had good success with them and i knew the Super Sports wouldnt handle the extra power. ive never had a drag radial feel this unstable. sport mode seemed to stabalize better than normal. But still not great.
pilotgore
US
A bunch
Definitely sounds like the softer sidewall is the culprit. What about track mode, I wonder if that would help mask the problem even more? Maybe give cup 2’s or supercar 3’s a try on the next set.
VuDoo350
VuDoo350
Utah
Nate
i'll play with it some more. I'll have to do some more research next go around. thanks for the input.
Andy13186
What PSI are you running? If they do have drag sidewalls you may need to lower it from normal, or experiment with the pressure. I found with drag radials at high psi the car felt insanely crazy, at lower psi it felt alot more stable but I think its just that the tire is so soft that high PSI made the contact patch tiny.
VuDoo350
VuDoo350
Utah
Nate
im hoping this is my solution. they had them at 39psi hot. should i run them around 30?
Inthehighdesert
NM
Charlie
Completely agree. Not a fan at all either.
VuDoo350
VuDoo350
Utah
Nate
I cant tell you how happy that makes me! SOOOOOOO many people are in love with that tire.
I get why, its hooks incredibly well. just a little disappointed in the handling side.
galaxy
St Louis
'17 GT350
And (on my sons S197 car), they're loud as f$%&.
I'm lost on the topic though; seems the answer is in the question. You made one change that induced said result. Not like you threw a bunch of suspension mods on at one time and now don't know what did what. Revers the one change that induced the unfavorable result. I know tires are expensive. Maybe borrow a set wheels/tires from someone just to test out the thesis.
VuDoo350
VuDoo350
Utah
Nate
ive thought about that, except most of my buddies are running the R888Rs lol. i did drop pressure to around 32/33 and it seems to be much better. Thank yall for the input tho.
lunatect
Prescott, AZ
Dennis
2016 Shelby GT350
What am I missing here? Why in the hell would you use drag radials and their soft sidewalls?
