Can't Activate Ford Pass
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
Just switched phones and reinstated FordPass. App says I have to activate vehicle. But, no way to do it. No message appears on display. Nothing. All it says now is 'Activation Pending.' Need a little help. Thanks.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
Did you create a new account? I use the same account on my iPhone and Note and when I had to reset my Note all I did was signed in. It was already saved.
Did you make sure you put the right Vin number?
Matthewstorm
Matthewstorm
NC
Matthew
I used the same info. It found my car. Said I had to activate it. Now it just says pending.
Soulja4187
Greenacres, FL
David
Go to settings and then go to FordPass reset/disable everything and then turn the car off for 5 minutes and then turn it back on. Within a couple of minutes it should prompt you allow Matthew's phone or whatever it says
Soulja4187
Greenacres, FL
David
If that doesn't help then I suggest doing a master reset by going to settings, general and then scroll down to reset. Also delete your car from the fordpass app and then resend the activatiom
Matthewstorm
Matthewstorm
NC
Matthew
I'll try that. Thanks.
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
Confusing OnStar app with Ford Pass ? :crackup: :facepalm:
Matthewstorm
Matthewstorm
NC
Matthew
No, it still says activation pending.
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Your modem may need to be reset. Mine did the same, ended up replacing the modem.
Matthewstorm
Matthewstorm
NC
Matthew
cactus_kid
Michael
'21 GT (see sig)
Dave2013M3
El Segundo,Ca
cactus_kid
Michael
'21 GT (see sig)
Still trying to justify the app ................
m3incorp
Georgia/Colorado
James
I'd say it is like most things; just for convivence. It doesn't do anything that you can't do by walking out to the car. lol I typically only open the app when I am away traveling and that usually is to check if I locked it or will need to go to the gas station when I return :) I feel you......no real reason for the app.
