camber and braking
thornclaw
northbrook, il
2015 mustang gt
it seems that too much negative camber in the rear impairs traction and acceleration. i wonder if the converse is true. does too much negative front camber impair braking?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Yes
luc
CA
2017 GT with PP
Handling is always a compromise balancing a lot of different factors
Obviously camber decrease the tire contact patch, and therefore maximum braking, in a straight line, it also increase, if negative, traction in turns
You gain way more in turns that you loose in braking
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Yes... but, it takes kind of extreme camber to cause a problem.
My car is running 3.2 degrees of front camber, and braking is still not noticeably impacted. Helps to have good tires (MP4S for daily duty). I'm still braking at up to 1.24g, fwiw.
TeeLew
So Cal
Tim
My guess is that we'd probably have to be well north of -4* to see significant braking loss.
Dana Pants
Burlington MA
Dana
2018 GT PP1
Yes. At -4 it’s obvious. Luckily at -4 you don’t have to brake too often.
