Screamer
All modular motors have no fillet radius on the crank journals or the crank snout area, in regards to a higher possibility of crank failure in a cross plane crank application would be mostly due to a harmonic issue.
The '05 Ford GT 5.4 had a large radius on the snout. The engine had to be short. That meant no cage like the Lightning and '03 Cobra. A prototype slung the damper through the ceiling in the dyno room. It was built with a stock 5.4 truck crank. The production GT crank had a large radius supporting the snout. The radius caused no space issues as the engine was dry sumped with an external oil pump.
The GT 500 still had a radius and rather than the short damper bolt the crank was drilled/ tapped deep almost through the oil hole of the front main journal. It then used a very long damper bolt to hold the damper and sprocket.Never saw a broken snout but did see several twist.
I built over two hundred mod motors and saw one broken crank. It was a supercharged 3V with a cast crank. It had a big Procharger and made 670 rear wheel. After two seasons of NMRA racing the snout broke right at the undercut.
