Ford Performance Air Oil Separator - Does It Really Fit Like This?
ARAMP1
Memphis, TN
2020 GT350
After some searching, it seems like the passenger side air oil separator fits different models, but here's the line from the canister to the intake on the GT350. I've fit it on both directions and it has quite a bit of a kink either way. Is there a better solution? Maybe a line from a different vehicle that fits better?
RookieDDZ
Central New York
Brian
2017 Mustang GT
ARAMP1
ARAMP1
Memphis, TN
2020 GT350
I have the other kit on the other side and it fits perfect. The short line is a hard line and the angles won't fit.
cerbomark
TN
21 Mach1 700, 6 Spd.#5558
Here s mine from a Mach1, yes different engine but I also found that top line to be too tight FYI.
NoXiDe
GA
GT350
I had the same kink issue so I decided to adjust until it didn't and the below were my results. I'll admit the fp instructions visually isn't the best. It is tucked underneath that one wire, however, it seemed to offer the least stress. Typically, I would have done it above.
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
I had a similar problem when installing mine. My solution was twofold. First, I warmed the flexible hose with a hair dryer to soften it a little, making it more flexible without kinking. Second, where the line attaches to to the seperator itself, I turned the fitting so the elbow points upward, instead to the side. This eleminated the kinks.
It's a little hard to see in my pic, but there are no kinks in the flexible part. But you can see the elbow attached to the seperator pointing up.
NoXiDe
GA
GT350
yup that’s how mine is as well
galaxy
St Louis
'17 GT350
What is that?
Catch can hoses from UPR. The ends can come off and cut the hose to fit perfectly. Looks great, no goofy kinks! The kinks in the stock lines aren’t an issue as nothings really linked or closed off, this option just looks great.
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
Do you have a link to the hoses? Very nice look.
bauern
somewhere else
Robert
F150 Powerboost
FWIW, any 5/8" I.D. or -10AN push lock hose will fit snuggly over the O.E. fittings. A gates heat shrink clamp will give a more finished look but no clamp is necessary.
