BREAK IN OIL
tonyd1
US NAVY,US ARMY,USCG-RET
New Port Richey,fl.
Tony
2018 Mustang GT Ruby Red PP,Automatic
How long, before you change it thanks!
EFI
Masshole central
5.Br0
There's no break in oil in the engine when it comes from the factory. It's just regular engine oil, and should be changed based on the recommended interval by Ford. No need to do anything else.
Now if you're rebuilding the engine yourself or at a machine shop then you should follow the recommendation from them or whatever break in oil you plan on using.
ricardocabesa
STD free
SW Florida
'17 GT w/PP
I never reached my intended 1st change at 2k in my EB before I traded it last month but I will change at 2k in the GT.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
There is no break in oil but I usually change at 3000 miles.
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Break in oil is for flat tappet cams and has high zinc content so the lifters break in with the camshaft lobes. Your engine uses a roller cam so it's not needed.
If you are referring to when to change the original oil I would say 1500 to 2500 miles to rid the engine of any break in small particles.
