2021 Break In Period & Oil
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
It's been many years since I've owned a new sports car.
I'm wondering what the break in period is for the new GT Premium. Do you have to drive it under a certain speed changing RPM's?
Also, do you do a 500 mile oil change? And which oil do you use in this car? In my C7 Corvette I used Mobil 1 0W40.
Thanks.
FreePenguin
Ohio
Donald
17 mustang
Amsoil signature best out there
Matthewstorm
Matthewstorm
NC
Matthew
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2022 Audi A5 S-Line
On my 2020 GT Premium I used variable rpms no harsh acceleration or breaking and not over 80 mph. I bought the car on April 2020 and it has 12400 miles so far
CorvZ061
Oxford, Ga
Travis
2022 GT
My 2020 GT has 8k miles, it saw red line several times the day I bought it new. Even on the test drive when I knew I’d be buying it. It’s seen wot a lot since then as well.
FreePenguin
Ohio
Donald
17 mustang
Really? What weight?
All the weighs. It’s tested first in basically every test. It’s a line in amsoil. Not cheap though. Not bad either if preferred custoner
Matthewstorm
Matthewstorm
NC
Matthew
boB
boB
2019 GT PP1
All this is in your owners manual (including using 5W-20 of any that meets the specs). I change oil & filter after about 500 miles to drain any early chips/casting flash but it is probably a waste.
Matthewstorm
Matthewstorm
NC
Matthew
Jeez, Amazon is charging $30.
Thanks.
Kleiss1
Anthem, Arizona
Gary
2018 Mustang GT 6- speed
The computer on the new corvette won’t let you hot rod it for the first 500 miles.
FreePenguin
Ohio
Donald
17 mustang
I pay 11 quart, free shipping over 100
I buy allmy vehicle oils yearly at once
luc
CA
2017 GT with PP
When was the last time that you heard of an engine failure due to “inferior “ oil ??? Seriously...
Amsoil and other hyped oils do not offer any meaningful longer engine life
Any modern engine can last an easy 200k using “normal” oil and most cars end up being junked for other reasons
And frankly specialty cars do in average so few miles that you will be dead or sold your car way before your car reach that mileage...
A solution in search of a problem.....
