Both Keyfobs Have Stopped Working
Abb0nz
Houston, Tx
Paul
2017 GT
Hey team, in need of some advice. All of a sudden my car (17 GT) won't recognize either of the two fobs. The batteries in one fob was dead so I replaced them and was able to remote start the car.
Now the car shows no key detected with both fobs. If I try to remote start the led on the fob flashes red. I can start the car with the fob in the cup holder slot.
Any ideas on a fix? I tried disconnecting the battery for over an hour but still nothing...
Torched10
Atlanta
Bob
Had that issue with my fob.try starting from ford pass,site.i think that,it resets battery monitoring system.it worked for me
Abb0nz
Houston, Tx
Paul
2017 GT
Replaced the batteries in the fobs twice, no change. The TPMS is now showing as faulty on the dash. Someone else mentioned a faulty RFA... anyone know if this could be the problem and how difficult it is to replace...?
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Yeah, if your TPMS isn't working either then the car isn't able to receive the necessary radio signals. Not sure which module that is exactly, but RFA sounds right. It may be part of something else that requires coding to replace, so this is probably a dealer trip kinda item.
KingKona
Virginia
Shlomo
2019 GT
Could also be the vehicle's battery needs replacing. That's where you should start.
ORRadtech
Atlanta, Georgia
Making sure that the car has the correct voltage is always a good starting point. Most auto parts stores will load test your battery for free.
Modern cars can exhibit some very strange symptoms when the battery starts to get weak.
Johnnybee
Canada
2018 convertible
+1 on the car battery. You want to make sure that is good before chasing anything else. The OEM battery is notorious for short lifespan. When mine was low voltage (due to not driving much in Covid) the door handles would not unlock the car (the fob would).
