Boost question
robmustang201528
15 mustang gt302blown
LA
15pp
How much boost is too much on 93 gas. Is 13lbs to much on a 15 block with oil pump and crank sprocket gears
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
We talking 13psi from a p1sc or 13psi from a d1x????
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I'd say that's a bit much. Swap to bigger pulley. What power level are you targeting? As you know, boost is an arbitrary number.
stang17
Wilkes Barre, PA
2017 GT Premium PP
I run 12-13psi on 93. Lately I've been adding a bottle of Lucas Oil octane booster at each fill up to be on the safe side in case I get a tank of bad gas. Car runs strong without any knock.
robmustang201528
LA
15pp
Who tuned it?
stang17
Wilkes Barre, PA
2017 GT Premium PP
Who tuned it?
Stock whipple tune, used flare to turn off all the safety features such as overload limiting etc, then used HP tuners to turn knock monitoring from global to per cylinder.
ahl395
Allan
Depends on your 93 quality and your timing. You can easily run alot of boost with 93 if you retard the timing a ton.
12psi @ 18 deg timing was the most I could get out of the very best 93. Between 15-17 degrees was more common.
You can run 13, probably even 14 or 15 psi, but you'll be giving up the power by reducing timing anyway, which has it's own disadvantages. You want a balance between the two. Run what your tuner recommends judging by your logs.
