shogun32
- Feb 8, 2019
- Northern VA
- Matt
- '19 GT/PP, '23 GB Mach1, '12 Audi S5 (v8+6mt)
- Vehicle Showcase
- 2
What's the gauge of the sheet metal? My guess it's just sufficient for the sacrificial setup. So when the mount is changed to rigid, the probability of failure goes WAY up.What I'm seeing in those pictures is fatigue cracking
Is there a way to get behind the sheetmetal? Is that surface even usefully flat? If it's slightly curved, the mounts will rock with enough force applied. A brace on the back side to spread the load across as much material wouldn't be a bad idea. Think of a thick-wall cup (id > nutsert, od < channel width) that is placed over the end of the fastener and held against the sheet metal with another nut (or itself could be threaded).
There are 2 failure modes:
* boneheads with lowered cars and no bump stops which drive the full compression-stroke shock-load into the bracket. This one can be avoided easily.
* 2000lbs of car traveling upward after a bump where the shock is acting in rebound. While the magnitude of the force may not be very high (if the damping was high enough the wheel would come off the ground) the 3" lever arm will exacerbate any rocking moments.
There may be a 3rd, which is the force put into the bracket should the shock top-out.
McMaster has rod-end seals as well though the SRI price is better. https://www.mcmaster.com/4737t14
