Best throttle body for a 2016 GT with a 18+ manifold on it.
Atxstang
Cory
2016 mustang got California special triple yellow
hey yall, im looking for some advice on what the best throttle body to put on my 2016 gt mustang. the current throttle is making noise and about to fail. the car has a 2018 manifold and is setup to run e85.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Find another stock one. There is no reason to go bigger. And you won't need a tune revision.
jacknifetoaswan
Charleston, SC
Stock 2016 or stock 2018?
JR
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
2018+ TB won't work on a '15-'17....
K4fxd
NKY
In 18 they changed it to digital control. Otherwise it is the same size. The stock 80 mm TB has been good up to around 900 HP.
So get a model year 2015 to 2017
Andrew@Lethal
West Palm Beach Florida
Andrew
Get another stock oem throttle body. You would not need a tune.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Stock throttle body flows 913 CFM. No need for anything bigger.
meauxcg
LA
C
08 GT500 Coyote
Ford Racing 90mm. 8-10hp and stock drivability and tuning.
Ignore that stupidity about the 80 flowing to 900hp, you can push 900 through a straw if you push enough boost. The tests with the 90mm are 8hp from the bottom to the top of the curve across the board this shows a restriction.
Grimreaper
Dallas
2017 GT
This on boosted or na setup?
Looks like Ford specified 913cfm for the 80mm TB. No go for 2015+
https://performanceparts.ford.com/part/M-9926-M5090
meauxcg
LA
C
08 GT500 Coyote
The 2015 issue is because of the throttle wiring. There is a harness to correct that now. Also JMS has a throttle enhancer that will fix it too
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
What made you dig this up?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
I have a stock 2016 gt tb i will sell you for $150.00, pm me if interested.
K4fxd
NKY
Got anything to back that up? Dyno graphs or 1/4 mile. And who does the tuning?
