Best cams for Gen 3?
CoyoteAntz
Rotonda West, Florida
Anthony
2019 Velocity Blue Mustang GT 6spd
I know Alex Flores says Comp cams Stg 2 is there another set out there that will yield more power gains?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Yeah, Comp cam stage 2. Comp cam stage 2. Comp cam stage 2. That said, a custom grind. Which means big bucks.
Like:
Valve lift
Int - .551 in (14mm) Exh - .551 in (14mm)
Camshaft duration
Int – 270deg Exh – 270deg
VictorH
South Carolina
Victor
2021 Mach 1
I happened to talk to Comp Cams tech support earlier this week. Cams like anything else is really part of a package if you're looking for optimum output. Anyway, they claim that the Stage 1 cam set increases power by 30 hp and brings power peak from 7,000 (stock) to 7,600 rpm. The stage 2 nets 40 hp and raises the peak power output another 200 rpm or so over the stage 2. Evidently, this assumes a proper tune (not really defined by them and they don't recommend anyone in particular).
drive_55_not
S,East
2014 Coyote, S197 3v, 2018 Gen3 [RIP], 2020 Challenger 'Cat
I don't who told you that but, that ain't happening with with the stock Gen3 intake ... Peak power is still around 7100 and drops like a rock ...
I agree unless you plan on a CJ swap, stock cams ..
4V Mayhem
US
2015 Mustang GT Premium M6
This isn't a pushrod engine, haha. A cam install will be costly and time consuming and might not be worth the gains you will see from them. But it would be cool and unique as not many people go that direction. If that is what you are looking for, a unique setup, then by all means give it a whirl. If you're just looking for more power then there really is no need to do a swap. The stock cams can make enough HP that you won't need to change them for anything that can be used on the street.
kevinvan6000
Ontario
2020Mustang GT
There is a huge backlog on the Gen3 cams from comp right now, at least for the NSR ones. People have been waiting months.
CoyoteAntz
CoyoteAntz
Anthony
Thanks!
CoyoteAntz
CoyoteAntz
Anthony
CoyoteAntz
CoyoteAntz
Anthony
Yup. Any money spent on cams would be better going toward e85 or FI.
I already am on E85 and I dont want to go Boost...thanks
