Base Stereo Improvement
Discussion in 'Infotainment and Electronics (Nav, Audio, Video, Bluetooth)' started by NoVaGT, May 16, 2019.
  1. NoVaGT
    NoVaGT Well-Known Member
    Vehicle(s):
    2019 PP1 GT Kona
    Sep 29, 2016
    Northern Virginia
    3,899
    2,460
    Rating:
    100%
    1   0   0
    I'm looking for a cheap, easy to install way to increase the sound volume of my base stereo. When I'm driving with the windows down, wind whipping, jamming to my 80s and 90s grunge, the sound just sucks.
    Is the kit from American Muscle the best way to get this done? https://www.americanmuscle.com/raxiom-jlaudio-base-stereo-upgrade-1517.html
  2. JackImpact
    JackImpact Well-Known Member
    First Name:
    Jack
    Vehicle(s):
    2016 Mustang GT Premium
    Mar 12, 2019
    Springfield, Ohio
    85
    You are probably paying a lot for them having made the decisions for you, putting it all in one kit. Which may be exactly what you wanted, to make it easier.
    If youre looking to spend for per volume and just getting everything you need at once than probably that will do it for you.
    Although you may be able to assemble the same kit, with better parts at the same if not lower price from perhaps crutchfield or sonicelectronics.
    My audio enthusiast friends love Sonic, but I think Crutchfield is better. Their website is nicer, their CS is better. Pricing wasnt really any different.
  3. Vicr
    Vicr Well-Known Member
    First Name:
    Vic
    Vehicle(s):
    2015 Mustang Ecoboost Premium
    Mar 8, 2018
    Snohomish, WA
    239
    119
    0   0   0
    X2. Crutchfield.
  4. JackImpact
    First Name:
    Jack
    Vehicle(s):
    Mar 12, 2019
    Springfield, Ohio
    85
    Also, you wont get crap for real audio support from AM (thats not really their thing, its not their fault) as you will from crutchfield.
  5. OP
    NoVaGT
    Vehicle(s):
    2019 PP1 GT Kona
    Sep 29, 2016
    Northern Virginia
    3,899
    2,460
    Rating:
    100%
    1   0   0
    Does Crutchfield have a complete kit for my car? Or can they put one together?
  6. JackImpact
    First Name:
    Jack
    Vehicle(s):
    Mar 12, 2019
    Springfield, Ohio
    85
    They can for sure help you build a kit, depending on your budget and how far you want to go.
    You may notice a huge increase just from swapping out the stock speakers, with no additional amplification.
    The stock speakers in 90% of cars, arent heavy enough to even be paperweights.
    Are you planning on installing yourself, or pay a shop to do it?
    **SIDE NOTE**
    It may be very much worth your while to invest in sound deadening, while this adds weight to the car which may not be something you want to do, the amount of vibration noise it will reduce in your door panels can help bring more sound into the interior of the car and can be done very affordably while you are already doing the door speakers anyway.
    I personally use (you probably wont need this many feet)
    https://www.amazon.com/gp/product/B00URUIKAK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    bjstang likes this.
  7. Captdistraction
    Captdistraction Not the Stig
    First Name:
    Vehicle(s):
    2016 mustang GT350 Tech Pack, 2011 Mustang Racecar, 2011 Raptor
    Sep 3, 2016
    Phoenix
    197
    33
    0   0   0
  8. Vicr
    First Name:
    Vic
    Vehicle(s):
    Mar 8, 2018
    Snohomish, WA
    239
    119
    0   0   0
    On Crutchfield's website you can enter your car's information and can search for only equipment that will fit in the stock speaker openings. They also sell wiring and mounting kits.
  9. StangTime
    StangTime Well-Known Member
    First Name:
    Todd
    Vehicle(s):
    19' GT PP1, Manual
    Apr 16, 2019
    Ontario
    707
    452
    Rating:
    100%
    1   0   0
    One of the biggest problems with the stock Ford systems is the factory EQ curve and variable loudness they apply to the signal before it get's amplified. If you do upgrade the speakers, I highly recommend getting Forscan and an ELM327 ODB programmer (with HS/MS switch) to disable the EQ on the ACM module and provide a flat response. If you go one step further and add any external amplifiers, you can also program the ACM module to provide line level output's and you can eliminate the need for a LOC (line output converter). There are many threads on the subject in the forums.
  10. Condor1970
    Condor1970 Well-Known Member
    Vehicle(s):
    Oct 4, 2018
    Port Orchard WA
    1,455
    512
    0   0   0
    Not to hijack the thread, but what are the impedance ratings for the front component speakers respectively? Are they 8-ohm or 4-ohm?
    I believe the rears are 4-ohm...
    ...So, if the fronts are 8-ohm wired in parallel, then they'll have a balanced 4-ohm circuit going to the stereo. If they are 4-ohms, then they would be running the front speaker channels at 2-ohms respectively.
    Anyone know exactly?
Loading...
Share This Page
