Automatic passenger door unlock
Deleted member 33561
Guest
By the way I had similar problems with the "service tire repair kit". It told me I needed to service the kit after one year. I went into the settings again I changed it to one year and then back to 4 years and everything was fine again.
Semp1
Valhalla
2018 Mustang GT PP1 Magneride
I took my 2018 GT PP to the dealership, for an oil change and tyre rotation.
At the same time, I asked them to check the door. They 'reset' it, and thus far it seems fine.
I will add. If I start the car via the Ford app, and then walk up to the passenger door, it will NOT automatically unlock. Must be a factory setting for that.
Works fine on the driver door...
Do you know what was done to reset it. I have the exact issue now. And yes the car sat there and was only started 3 times since Nov so it could be some weird lower save glitch.
Semp1
Valhalla
Sorry to be late to the party... There is a setting for the door locks- on my 16 it is in the options menu in the instrument panel. I get off work at 1am and have to go to a big half-empty parking garage, so I did NOT want the passengers door unlocking at the same time as the drivers'. It will still unlock if I'm standing next to it with the fob, but from the drivers side it requires me to use the unlock button on the fob or inner door.
There is no specific drivers side passenger side intelligent lock option. At least not with the digital dash on an 18. Can you please further explain because I have the issue now.
ivantwilliams
ivantwilliams
Georgia, USA
2018 Mustang GT Premium with Performance Package
Not sure. And, to add, I feel my car still does it from time to time.
Example, if I start the car with the Ford app, and walk up to the passenger door, it will not unlock. But, I also swear from time to time, even when I have not started the car via the app, the passenger door does not unlock.
I can never replicate it, specifically. Thus, harder for Jim Tidwell Ford to resolve the issue permanently.
lacanteen
Louisiana: Cajun Country
George
If the key fob is in my pocket either door unlocks when I try it. If a traveling companion tries to open first it will not open if I'm on the driver's side. Only after I open the driver's door will the passenger door then open for them.
Ecoboosted
A state in the South East of the US
18' Mustang GT, 19' Road Glide
My 18’ has this issue. With the fob in my pocket I can’t unlock the passenger door by grabbing the handle but I can unlock the drivers door by grabbing the handle.
ivantwilliams
ivantwilliams
Georgia, USA
A tad bit annoying...!
Decosse
Las Vegas
Dana
2019 Magnetic Metallic EB 6MT 101A (RIP 2016 V6)
I don't know about 2018s, but on my 16 it's in the info screen (between speedo and tach), under settings. It can be set for both or driver's first. It's page 86 in the 16 owner's manual. I haven't any idea where it would be on the 18s
ivantwilliams
ivantwilliams
Georgia, USA
I will double check. But, something tells me, when I first got my car, that was checked and set accordingly...
Semp1
Valhalla
It’s supposed to work that way.
bdm219
Connecticut
2019 Mustang GT PP1, 401A, AE, B&O
I have the same issue with my passenger door. Once in a blue moon, it'll unlock. More times than not, it's just dead. My car is put away for the winter, I'm going to have the dealer look at it in the Spring. Mine isn't a setting, as 15% of the time, it'll unlock. At first, I thought it was a fluke, but it's dead more than it works.
ChaoticFury09
Toronto Ontario
Nathan
2019 GT Premium (Automatic - Magnetic)
I had this problem on my 2018. I took it to the dealer and they confirmed it was an issue. First they replaced the entire door handle and it didn’t work and then they replaced the bcm and it did.
The only other thing I found to be a factor was a dash cam. If my dash cam was hard wired it would stop that door from working no matter what fuse I tapped. Once I plugged the dash cam into the cigarette lighter it stopped being a problem.
Rumble GT
Toronto, Ontario
2019 Mustang GT prem - Orange Fury with black racing stripes
I have the same problem with my '19 GT and I suspect this has to do with low battery. My car is driven once or twice per week for very short joyrides, the passenger door will usually not respond to me touching the handle after sitting in the garage for few days. Right after each joyride it works just fine, then after a few days it dies again.
People who drive their mustangs more often seems to have no issue
Guest
That is exactly the problem. I confirmed that by connecting a charger and disconnecting it. With charger connected it worked and when disconnected it didn't work. A short drive cured the problem. (2018 Mustang GT)
ChaoticFury09
Toronto Ontario
Nathan
Interesting finds. Does anyone else get notifications from Ford pass about things being disabled due to low battery voltage? Seems odd to be getting them so often.
