Arh headers with cats wont pass emissions test?
Khyber
it's a hard parked life
Lexington/Myrtle Beach, SC
Landon
2015 GT PP CO
there is always mak cat delete pipes. when you need to pass emissions just put factory cats back on in minutes.
Silver50Pony
Westchester NY
2015 5.0 PP Ingot Silver
At best a set of shorty headers might get you 10rwhp. They just aren't that much better than stock.
Was looking up the results the kooks 1 7\8 shortys from s197s were making every bit of 20 rwhp with stock cats plus a few lbs weight savings
Nick@JDM
www.teamjdm.com
Nick
2014 Tremor
Catted headers technically WILL NOT pass emissions because they are not 50 or even 49 state legal since they have been moved from the OEM location. Now, some tuners, like Lund Racing, can set the tune in such a way that when connected to the scanner for the readiness testing they can get you a "PASS" reading. Some states this cannot be done in, like CA, NY, VA and some others. I'm not sure off the top of my head which states they cannot "trick", but the 3 I listed I know for sure.
The difference with the Kooks Green Cats is that a tune is not needed with those, so you do not have to turn off the rear O2's which will get you a "FAIL" on the readiness test.
You can add NJ to your list as well. After you drive over a camera and they verify you even have cats, they plug into ODBII and check for reediness. If we have the rear O2s "turned off" you fail as they know these system should be operational. Our best bet here is Kooks headers with Green cats and "O2 non-foulers (spacers) between the rear O2's and the pipe. This will usually provide enough heat to not trip the rear sensors but there is no guarantee on 2011+ cars.
NY also works this way as well but I am hearing rumors that they will soon enforce the visual aspect even further. If you have after market exhaust parts and no CARB "soon to just be ARB" sticker they can fail you as well.
It's disappointing to see this but the EPA isn't messing around these days.
What really irks me is there are not longer any safety inspection in NJ. You can roll in with malfunctioning brakes, no rear view or side view mirrors, broken windshield, no headlights ect.. and pass as long as the car shows OBDII readiness. This is Ass backwards IMO...
Cloak
Northern VA
www.instagram.com
2019 Shelby GT350R Shadow Black
I am in the same predicament. I live in Northern Virginia, where obdII emissions tests are required every two years to renew registration. I work at a dealership, so I have plenty of techs that don't mind overlooking the visual inspection, BUT rear o2 banks being turned off is an automatic failure. There is no way around it.
If there was someway to add spacers to the sensors that would read ready, and not throw CEL, I would have longtubes yesterday.
Kashawy
Gold Coast, Australia
Khaled
2015 CO Mustang GT, 2012 Black Golf GTi
I must be lucky that I don't have these kind of inspections here, sounds like a real headache. Yet, I still went with catted headers.
Silver50Pony
Westchester NY
I was told by 2 different tuners that kooks green catted long tubes Will pass and no CELs
beefcake
Bethel
2018 Ford Mustang
phrenetiK
IF YOU QUOTE PICS I H8 U
houston
2015 GT Premium PP Recaros Race Red
I went with catted to avoid the fuel smell. Plus, the difference in loudness and power is very minimal.
is that so? every dyno ive seen the catted headers make only half of what the catless headers make....no way id spend extra money to make less power.
beefcake
Bethel
2018 Ford Mustang
mustang_guy
United States
it has an engine!
Ill be doing this. Im not worried about visual inspections for being catless.
phrenetiK
houston
