APR Studs on non-R?
galaxy
St Louis
'17 GT350
I’ve got Signature wheels on my non-R with Signature titanium lugs. What will the fit be like if I swapped to the R length (or extended) APR studs? Or R spindles with studs already in them? Will tbe stud extend to flush with the lug nut both f&r? Surely someone has done this or similar combo.
@50 Deep
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
Did you reach out to Terrance? If I recall, they specifically made the lug nuts the same length as the studs with the wheel mounted. But I think it’ll depend on your offsets.
NGOT8R
Adrian
2019 Bullitt
ARP studs are hard to come by. I called everywhere, including ARP direct regarding wheel studs for the S550 and they told me they wouldn’t be shipping any until the end of June.
Epiphany
Global
I like to disassemble things.
Supply side issues still suck, for everybody.
SchnellGT350
Danville, CA
Rob
2020 GT350
Managed to grab a set of front and back hubs from OP Mustang with R length studs. Keep checking their site.
galaxy
St Louis
'17 GT350
Saw the hubs at OP, but that drives the cost up a bit, but makes install a lot simpler. I like the gold/bronze color of the ARP studs though, LOL.
JeremyPro5.0
CT
Jeremy
2020 GT500 & 2018 GT350R
That's what happens when everything gets sourced to China and their idea of handling a pandemic is to lock everyone in their house with a metal gate and a padlock.
WItoTX
Houston
Kyle
'17 GT350
I'd have to to see photos of your rims to be sure, but on my car, I have the GT4 studs and they stick way out. Once I go square, it will not be an issue,but for the time being, they are very long.
Reach out to Tim at OP. Good guy to work with, and pretty straight forward.
SchnellGT350
Danville, CA
Rob
2020 GT350
They do sell just the studs. I am lazy and was looking for simpliest install
Tonymustang302
Chicagoland burbs, IL
Tony
2017 Turbo GT, 2019 GT350 racecar, 2021 GT500
Fronts are so easy. Rears are brutal
SchnellGT350
Danville, CA
Rob
2020 GT350
Thinking I may have my shop do the swap. Not sure my patience will hold up. Is it mostly just the disassembly of the parking brake that makes it so painful?
Epiphany
Global
If you have the right tools the PB isn't an issue.
galaxy
St Louis
'17 GT350
Yeah, parking brake isn’t too bad. I guess just getting the axle nut off to get the spindle off is the biggest part. I’d take the spindles to the machine shop to get the actual studs swapped out though.
50 Deep
Signature Wheel Ford Rep
Gold Sponsor
Sacramento, CA
www.signaturewheel.com
2017 GT350R
The end result should be ideal. The lug nuts will sit flush with the longer studs. Do it!!
