Anyone else notice... (in regards to wheel hop)
Dfeeds
Illinois, US
I see wheel hop pop up quite a bit and how had it is on the s550 and also how people don't have it.
I was one of the "don't." If I spun my tires that was it. I didn't get any hopping. However, I recently had traction control on (I usually keep advanced traction control off because, assuming warm tires, the car grips real well) and got on it. The back end kicked a little bit and I felt what seemed to be some nasty wheel hop. This wasn't the first time I noticed it but I never really put two and two together.
So, at least for me, it seems advanced traction control off = no wheel hop. Traction control on = wheel hop.
Has anyone else noticed this?
NightmareMoon
2016 Mustang GT PP
Well Ford made some changes to the rear suspension on the 18+ cars to help with wheel hop, so theres that.
Dfeeds
Dfeeds
Illinois, US
I wasn't aware. But I'm still curious why traction control would cause wheel hop. I dug up an old gt500 thread where they also were saying turning it off helps with wheel hop. I have some sort of idea that I can visualize with the brakes causing a rapid shift in wheel speed and traction that promotes wheel spin, but it's hard to correctly articulate.
NickZ
middletown, NY, USA
Nick
2020 Velocity Mustang GT, 2017 Lexus GX460
You have the IRS bracing on?
I have em and it seems to put down power down better than b4, but since most of the time my EB can spin its tires, I can't give more opinion on that, but the car FEELS better at putting down power...
Flimflamman
Kennesaw, Georgia
2019 GT A10 & 301A
By turning traction control off, you mean holding the toggle up for 5 or so seconds to completely disable it? If so, I haven't done that yet. And I haven't experienced any wheel hop yet. I haven't been to the drag strip either. I guess it depends on the road conditions as well (uneven, bumpy). I don't have any suspension/performance mods yet.
Dfeeds
Dfeeds
Illinois, US
I'm actually not sure. I didn't think the pp1 came with any additional bracing for the rear IRS. My car is a bone stock pp1 apart from the power pack.
Yup, that's exactly what I'm referring to. I also don't have any suspension mods. The car feels so much peppier with it turned off so I do so almost religiously.
NickZ
middletown, NY, USA
Nick
Maybe try out the Steeda IRS subframe bracing.
S550's rear end flexes too much, at least for base EB. Turn in to the drive way you can just hear the squeaking from behind...
The bracing fix that for sure
Dfeeds
Dfeeds
Illinois, US
I wasn't necessarily asking for a fix, though I appreciate any advice. I find the wheelspin very manageable and predict with traction control off. I was just curious if others noticed they no longer had wheel hop with adv trac off.
NickZ
middletown, NY, USA
Nick
Em, I see. Mine don't even have the option (I think) lol
Andy13186
depends on the surface and how hard you are spinning, and also tires etc. Usually the stickier the tire and surface the worse the wheel hop is if you do spin.
Bluemustang
2015 Mustang Base GT
I don't think it's wheelhop you are experiencing as much as you are feeling the TCS/ESC kicking in - cutting throttle and applying brakes as necessary.
But it could be wheelhop is induced when the system kicks in sharply.
tj@steeda
Timothy
Here ...
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
Wheel hop can be more pronounced on a prepped drag strip track. The BMR lockout kit really helps there and also in just nailing it from a stop as it helps the tires dig in.
