Anybody using Viking double-adjustable rear drag shocks?
WoodburnGT
Oregon
2022 Mustang GT
Viking gives some base settings for starting out, but I’d like to hear from some actual user’s experience. Maybe what you started with, and the range you’re in now.
Thanks
Kennysum1
Huntsville, Alabama
Kenny
2017 Alfa Romeo Quadraflio, 2018 TT GT Prem, 22 GT
I am running Viking Crusaders. Currently running 12/12 on mine but had some slight wheel hop @ around 850 hp or so.
Running BMR drag springs, BMR chassis lockout, Viking Crusaders and Mickey Thompson Street Rs.
It is really going to depend on your HP levels, tires, track etc. You will need to take your car to the track you run at and make some passes and see what works for you while using the Viking base settings as a starting point.
WoodburnGT
WoodburnGT
Oregon
2022 Mustang GT
Thank you. Our track opens this weekend. I hope to get plenty of pass’s in.
Kennysum1
Huntsville, Alabama
Kenny
I see it says you have a 2022 GT? If you are running a stock engine or anything close you do not need crazy expensive shocks. Just a decent set of tires and you should hook right up.
WoodburnGT
WoodburnGT
Oregon
2022 Mustang GT
I bought this to be a dedicated bracket car at my local track. Won’t be driven on the street ever…..it currently has BMR drag springs, billet vertical links, billet camber arms, Kelltrac IRS kit and Vikings…..along with Weld Wheels and M/T ET Street R 305/45R17’s. It’s also getting Kooks headers and a E85 tune.😂….I know, a bit much…..it’s been a fun project so far.
Kennysum1
Huntsville, Alabama
Kenny
You will hook no problem lol
beefcake
Bethel
2018 Ford Mustang
Thanks
We run Vikings on most of our shop builds, even ran Viking shocks on our 2017 GT with Air Ride.
Settings really come down to track conditions, tire and full setup. Typically recommend going with the basic settings and make adjustments from there. Then once you get it dialed in for the track you can keep the specs for street too or some guys have street specs and track specs.
If you don't have them hit me up and I can get a set going for you, keep them in stock as well.
Feel Free to DM me or call with any questions.
Terry "Beefcake" Reeves
Office - 855-TBR-RACE
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
WoodburnGT
WoodburnGT
Oregon
2022 Mustang GT
Thank you👍👍
PickleGT
Wisconsin
2017 Ford Mustang GT
Any updates on the viking settings? I installed a set and my 60 foots got worse.
beefcake
Bethel
2018 Ford Mustang
there reall aren't settings updates, you have to adjust based on track conditions, suspension, tire, etc.c.
we video our launches and make adjustamnets from there
PickleGT
Wisconsin
I meant updates from the OP on what setting were working for them or anybody else that’s been having success. obviously my starting point was wrong so i was hoping for a better start point next time at the track.
beefcake
Bethel
2018 Ford Mustang
well, thats the rub, every car every track is different, typically you start over with base settings, or , if your going to same track you normally do with consistent prep, you should get a good handle on that particular track
it's always a bit of a process til you really get to know your car
1Slow5PointOh
Georgia
Gerald
2015 Mustang GT premium PP
I don't mean to derail the topic but I'm pretty sure you guys are one of, if not the only shop to run airlift on an S550 drag car. Did you guys immediately upgrade to the viking rears or did you have some success with the airlift rear shocks? Only asking because I have airlift on my TT car and wonder if it's worth attempting to dial in or if I should spend the extra cash and just go viking rears with an upgraded shock mount.
beefcake
Bethel
2018 Ford Mustang
We always go straight to the Viking shocks to get more control with our airlift packages
we have cars going in the sevens now with them
All the models to my personal challenger we have the air lift on and we’re running the Vikings there as well
PickleGT
Wisconsin
easier said than done when the local track is only open for test and tune one night for 5 hours every other weekend so runs are limited and frustrating when factory shocks were figured out to get multiple 1.65-1.66s and you spend $600 to go 1.7s
