Depends. Ask the FI guys I've beaten.Isn't "Fast - N/A" car an oxymoron or contranym?
He does roll racing 60 to 130. Not digs. With the wide spread of the A6 and his high RPM power band the gear will help. The taller tires will get better traction.first will be useless. He'll need a PBH planetary.
The FRPP tune for the auto shifts at 7400So can a gen2 with only an intake/tb/IM rev to 7500 safely?
Yeah, I know FP thinks it’s safe and even warrantied back in the day. I’ve just never heard a straight answer as to why the stock redline is 7000 when it has B302 internals (except cast pistons) or better and the gen3 with the same rotating parts is redlined at 7400. I think I blame the stock IM which keels over after 6500.The FRPP tune for the auto shifts at 7400
60 to 130 is pointless with 2000 hp Lambo's out there.He does roll racing 60 to 130. Not digs. With the wide spread of the A6 and his high RPM power band the gear will help. The taller tires will get better traction.
Probably because that’s where ford wanted the power band. The kept the rpm’s lower and wanted to increase torque. You can rev a stock coyote over 8k rpm. I’ve done it a bunch and nothing has failed because of it.Yeah, I know FP thinks it’s safe and even warrantied back in the day. I’ve just never heard a straight answer as to why the stock redline is 7000 when it has B302 internals (except cast pistons) or better and the gen3 with the same rotating parts is redlined at 7400. I think I blame the stock IM which keels over after 6500.
but lots of gen2 folks go to 7500 with unopened engines all the time, right?
That is the answer. The FRPP tune is based on the gt350 mani. Even the FRPP2 tune is almost identical to the FRPP3. I think the reason for not going higher with the 350 mani is due to the cams crapping out about 7500I think I blame the stock IM which keels over after 6500.
Makes sense.That is the answer. The FRPP tune is based on the gt350 mani. Even the FRPP2 tune is almost identical to the FRPP3. I think the reason for not going higher with the 350 mani is due to the cams crapping out about 7500
