Another 2018 Whipple Stage 2 Install
rtg
CT
Rob
2018 GT PP1+
Started the Stage 2 Whipple install. I will post some pictures as the install progresses.
Rob
Up on stands
Battery out
Fascia off
Will update progress over the next few days.
rtg
rtg
CT
Rob
2018 GT PP1+
OPG and sprocket already done. Also have the half shafts, BMR lockout, and Eiback Pro kit installed. Been holding off on the Whipple install until some miles but at 1974 miles and no issues(knock on wood) getting too impatient.
So we're off to the races....
Rob
cnycomp
Syracuse NY
18 Mustang GT
Rob
Sounds just like I thought! 2100 miles here and I put the procharger on this week!! Let R Rip!
rtg
rtg
CT
Rob
2018 GT PP1+
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Nice man keep the pics and progress coming, many will be interested in this thread and install.
rtg
rtg
CT
Rob
2018 GT PP1+
Continuing on... Just some pics at different stages of the process.
Draining the anti-freeze. Only about 1.3 gals comes out but no flooding when the heater hoses are disconnected.
coolant plumbing disconnect.....
Air box on it's way out....
Air box gone. Attacking the intake connections...
Once intake is unbolted there are a couple of connections in the back that have to be removed. The intake is lifted up and moved forward.
Intake is gone. Gas in the fuel rail goes everywhere on removal.
Spark plug replacement. Gapped 0.028" and some anti-seize.
At the turning point of original parts removal complete. Now on to the install....
Rob
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Awesome job love the pics and blow by blow. I remember also when pulling the stock intake fuel spilled out forever.
rtg
rtg
CT
Rob
2018 GT PP1+
Got some more done but need to call it a night. Back at again tomorrow.
Did find that although I thought I had done a good inventory I am missing an o-ring. I am going to to try using the OE o-ring as it is on the coolant side it is easy to get to. Plus it still has solid interference fit. To now other than that going smooth. Instructions need a revision and should include actual part numbers of items to install.
Drivers side heater hose modification. Cut the factory hose and use shrink clamps to splice in new hose.
Splice complete....
Anti-chafe weave covering on the whole hose.
Mod completed.
More tomorrow. Hopefully the SC will be mounted.
Rob
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Looks great! Can't wait for track results!
rtg
rtg
CT
Rob
2018 GT PP1+
Progress continues....
Coolant tank overflow hose
Have to remove 1" of hose for clearance
Air Charge Temp interface cable goes to left side IMRC connect. It is the one that is in the middle of the firewall.
Ground connection for SC coolant pump relay circuit
Use the ABS circuit to energize the relay. I drilled a 3/32 hole on the fuse panel to secure the wire.
The relay is mounted under a harness connector.
Harness connector back in place. Pump inline fuse is secure to an AC hose.
Pulley bracket is easier to install by putting tape of the screw heads to keep them and the spacers from falling out.
Installed
Adjustable idler
Installation manual references a plastic pulley. I had a metal one from the factory. I did use in the one that came in the kit.
Kit pulley
Spring loaded tensioner
Clearance to AC hose. You need to move it over a some. I my case not much...
Another view
Preparing the SC.
Here are various views of it right out of the box.
More later...
Rob View attachment 308078
engineermike
La
2018 GTPP A10
Did you have any issues woth the tensioner pulley contacting the ac compressor clutch?
rtg
rtg
CT
Rob
2018 GT PP1+
Not that I noticed but will take a look. I don't have the belt on it yet.
Is there interference with belt on or off? Also I have not gotten to this point yet but am thinking moving the adjustable idler will move the position of the tensioner.
Rob
