Alignment question?
thebaldlatino5.0
Beeville, Texas
Carlos
2017 Ford Mustang GT PP
I will be installing Steeda Camber plates up front and adjustable camber arms and toe links to my 17 S550 GT. What is the ideal balance of camber for (1)Daily driving, (2)autocross, and of course (3)roadtrip/spirited driving? Want best tire contact patch and best look all the way around possible. Thank you.
Tuxedomouse
Cinci, OH
17 GT Grabber Blue Premium PP
Probably something around 1.8 front and 1.5 rear. I'm running 2.0 on the front and it's awesome, can't speak to wear yet, I don't put on a ton of miles
thebaldlatino5.0
thebaldlatino5.0
Beeville, Texas
Carlos
I dont either, I have a daily I use cause I filled up sunday and still full. Lol
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
I run -2 up front and -1.6 rear. Total toe is 1/16 front and same for the rear. Thrurst angle is 0
I love my set up. Wear is even across-the-board. Handling is superb
NightmareMoon
2016 Mustang GT PP w/ Voodoo
There is no balanced camber for atreet, track, autox.
you want 3 degrees (or more) for track and autox and you want like 1.7 for the street.
2.7 (which is what I’m running) isnt enough for autox/track to avoid some extra shoulder wear, and its too much to get the full life out of street tires (which will probably die on the inside edge a little early). I spend more $$$ per year on track tires than I do replacing street tires, so I optimize on that side of things.
On the rear axle, you can go to 2.0 before you start loosing straight line traction too quickly.
