Aggressive Fitment Thread
S550 Sema
North Jersey
2018 GT PP2
Work wheels are relatively cheap as well [emoji1303]
IG - S550_Sema
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
There are alot of really good quality wheels, I always recommend speaking to a vendor so they provide deeper insight then oh that wheel looks good and all that.
Educating the masses on wheel quality is a big thing, thats why we hand select every brand we carry.
ronnieb1958
Inglewood, Ca
Ronnie
2015 Ecoboost Premium
Thank you for the praise! :cheers:
Yes, the Forged wheels are on the higher end side, but we do have a wide range of costs in the Forged line up as well. FlowForm for sure is the least expensive of the wheels we do make though, and seem to be huge for the Mustang market :)
I just wish you'd make those FF01's in a 19x9.5 and 19x10 square fit...sigh!
WKT
I Bleed FORD Blue!
Hilton Head Island SC
Keith
2018 GT350 Lead Foot Grey
Excellent job Boardcat! I do believe that is about as aggressive as your going to get width wise! I read your post on the SCCA thread about the fitment, nice job.
boardkat
CAMtard
Lake Oswego, OR
'15 GT
thanks, it took a lot of measuring, calculations, patience and little bit of blind hope! always nice when a plan comes together :)
i agree this is about as good as it gets under stock metal. sky's the limit once you start cutting though. my ultimate end state is 18x13/345s square, just gotta build up the nerve to break out the sawzall! this will suffice just fine for now though :)
WKT
I Bleed FORD Blue!
Keith
That would take more nerve than I've got LOL
Built4Speed
2016 GT Premium White
WOW! :clap2: :clap2:
Would love to see some full car side/front/back pics
18x12 w/ 335/30R18, that's all 4 corners with no rubbing?
What offset are the front and back wheels?
Any spacers front or back?
boardkat
CAMtard
Lake Oswego, OR
'15 GT
this is not a setup that i'll be competing on - in that, i'm running too much rear camber right now, not enough front and rear spring, and haven't cut/flared front and pulled rear fenders yet. still a work in progress - i only ordered (2) wheels to start, since i wasn't 100% sure i could get this offset to fit with a "reasonable" spacer on the front (so that i can rotate front/rear). turns out it does (barely) with a 1.5" spacer. no spacer on the rear (obviously). not sharing offset at this time, until i've got a few races under my belt (but there was no static rubbing, and a trip around the block was uneventful); regardless, it's definitely not a "bolt on and go" setup, considering the mods necessary, so it wouldn't serve much use anyway.
i'll definitely post full-car action shots later this season!
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
I just damn near pissed myself seeing this setup, holy balls lol
As much research as I have done and just touching the 11" all around fitments for the 19s and 20s for functional fitment, this just blew me away.
I applaud you sir.
Schu
Las Vegas, NV
S550GTPP
I had a good feeling 12" rears were going to be easily workable... perhaps with a 11" front.
What offset are those boardkat?
Built4Speed
So I'm going with a 20x10 +45 offset wheel w/275/35 tires square setup. I've done a lot of searching but can't seem to locate a 5mm or 10mm hubcentric spacer for the front. I want something very high quality. Can anyone help me find these? 2016 NON-PP GT.
Thanks in advance.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
I had some eBay ones that I got for about $20 on my 13. They were 5mm. Never had any issues. No vibrations or anything.
Anything beyond 5mm and you probably want to get the ones with extended studs but those are way more expensive.
Supa LA
Drop a gear and disappear
So. Indiana
2015 Guard Metallic Mustang GT PP
Thanks in advance.
I am also looking for a 5mm spacer for the front and rear. Let me know if you have any luck!
