Aggressive Fitment Help
lopezgera92
San Diego, CA
2016 Ford Mustang Ecoboost
I've done quite a bit of research and I believe I finally know exactly what i'm looking for. But I thought I could use some feedback before pulling the trigger on the wheels and tires. I drive a 2016 ecoboost and the look i'm going for is low and wide. I would like the wheels flush and as low as possible without tucking (or kept to a very minimum).
I have already purchased a set of coilovers. I got a really good deal on a set of BC Racing BR Type.
Here are the specs for the wheels and tires:
Front
Niche Intake 20x9" M159 Wheel 5x114.3mm Double Dark Machined Black
Offset +35
Rear
Niche Intake 20x10.5" M159 Wheel 5x114.3mm Double Dark Machined Black
Offset +45
Front
Continental ExtremeContact DW 265/35R20
Rear
Continental ExtremeContact DW 315/35ZR20
Do you guys think this would be a good set up? I appreciate any feedback
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
Front
Offset +35
Rear
Offset +45
Front
Rear
That's a standard fitment your good without issues rear you'll adjust to -2 degrees camber and that's it.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
The front will tuck a little. You can run the 10.5 upfront too. Move up to a 275 on the front and the 315 rear. Or do 285/295 on all 4 corners and still be able to rotate and save a ton on tires.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
S550VERT
2016 GT vert
help me as well please, I just Ordered GT350 SVE wheels from LMR. The rears are a 305/35/20 and they just barely squeeze them in. here is the wheel specs
Wheel Specs
Finish: Gloss Black
Backspace: 7.07"
Offset: +40mm
Weight: 26.4lbs
thanks in advance.!!
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Wheel Specs
Finish: Gloss Black
Backspace: 7.07"
Offset: +40mm
Weight: 26.4lbs
Adjust the rear camber spec to -2 to -2.2 and your good
Cali
18guy
Mustang GT auto
Anyone know if i can run 20Ă—10.5 on front and rear for 2018 gt also want to put 305 35 on its lowered on eibach pro kit ,, thanks
Grintch
Hunstville
2015 GT PP
So, let's compare to a EB PP. Front tires +10mm, rear tires +60mm.
Do I have to draw you the map to understeer city?
An aggressive fitment would be 11" wide front and rear or 11/12" front and rear with stiffer rear springs/bar to avoid understeer. 9" fronts are wimpy, not aggressive.
barkingspud
NW burbs of Chicago
2019 Mustang GT Premuim
Ok. My turn. Shelby CS-3 wheels on a 2019 GT.
Front 20x9.5 +40 275/35/20 Conti ECS
Rear 20x11 +50 315/35/20 Conti ECS
Any concerns? Would a 325 work in back?
Thanks in advance!
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
Did you get this done?
